Eurolock door locks - house break in waiting to happen?
Edinburgh Scotland
I remember bringing this up a number of years ago when I upgraded the lock on my conservatory door. What's brought me to focusing on it again is that a neighbour has just suffered a break in due to this type of lock making it very easy for the villains.
They have just bought a new and very posh high performance BMW - Probably buy about 20 Backies (our 1.2 Panda) with what it cost. Their front door is a modern UPVC type with the typical Eurolock cylinder type lock. Here's an example: https://www.screwfix.com/p/union-6-...3tSOqcFEynIY-HJ0AIRoCBT4QAvD_BwE&gclsrc=aw.ds Apparently it took these villains just minutes to defeat the lock and get through the front door - I presume to steal the car keys? - Unfortunately for them our neighbours also have an inner vestibule door which was retro installed by a joiner and is a solid bit of kit with a separate, robust, door lock of it's own which they were unable to get through (or perhaps decided to give up when they encountered it?) Anyway, whatever the reason, they gave up.
They've had a locksmith round today rectifying the damage and fitting a new lock and he has explained to them that the original eurolock which was in the door was probably the one fitted some 45 years ago when our houses were built and was of a very basic design and easily broken. Although still available today, he advised them to replace it with the newer version, which is interchangeable, but is anti snap, anti bump (anti bump?) anti drill, etc. For example like this one: https://www.screwfix.com/p/yale-fir...euro-profile-cylinder-40-50-90mm-nickel/7085t About 4 times the cost of the old spec lock but much more robust.
He, the locksmith, said he's coming across these early design locks every day and they are so easy to defeat that, if your's are that type, you need to check them and upgrade to the newer type immediately. If I've understood him correctly, the old design can be easily snapped in half and then the bits extracted with long nose pliers or similar but the new type breaks off in place leaving most of it behind in the door thus blocking access to the mechanism.
So there you are, just thought I'd mention it. My neighbour's wife is very emotional about the fact her house has been "violated" and I wouldn't want anyone to go through that when it's easily avoidable.
I think this depends on the rest of the door, fix the lock and they'll kick a panel through instead if it's your standard double glazing door with interchangeable top and bottom panels.
That's a good point. I've never changed my front door from the robust wooden door fitted by the builder. A much more robust thing than the more fashionable stylish modern doors but needs maintenance, like painting, from time to time.
I keep thinking I'm gonna to get composite doors which should solve both. Also the fact Stevie Wonder installed my letterbox with a 4 pound hammer and a spoon.
But as I've not got 70 odd grand of car outside it's less of a concern...
Locks on my house and daughters new doors are the highest available spec. They say you get money if anyone gets in by defeating the locks.
All you can try and do is make your place much more difficult than your neighbours to enter. I did modify our patio door adding a legth of wood above the door. This means the door will not lift up more than 0.3 of a millimeter. This replaced. the weedy 1 inch square anti lift blocks. I dont think.they did much for our security. Its always good to get reminders to check!
uI finallyreplaced the porch theshold today at the bungalow. What a mess that was. But now its got new foundations of hardened concrete and engineering brick linked to the internal floorwith a dpc and new membrane over the new edges and existingfloor slab. It took ages to get it dead level. The sill will go in tomorrow and maybe the door. I have reinforced corner posts with tensioning jacks then side panels. Ive paid for laminated glass with film as well on the inside. Windows have 8 point locks with top and bottom shoot bolts. I think the dog does more than the locks for security though. Few people brave passing the beware of the dog sign here. Hes a sweet lad but if he decides Rachel is threatened by ANYTHING, including me shuffling to the bathroom. I dont move till he says its OK. He doesnt like any noises or sudden movements especially if she is sleeping. I think he is more or less awake all the time she sleeps. Ive a remote security camera to fit and will be adding an alarm before I am done.
I’m going to seriously consider getting one of those locks to replace the one in the back door.
We have one security system which is extremely difficult to defeat.
It sounds the alarm if anyone so much as walks up the drive, so opening a door is bound to trigger it.
They have 4 legs and bark like a psychopath if triggered. While they are quite small and easy to move around they sound like a much bigger dog
I have replaced both our front and back door lock cylinders with these. Not cheap, but pretty secure, and easy to fit yourself too.
We also have a 'stealth' movable security system as well. In as much as, He'll let you get in, (lies quietly in wait) but then, if he doesn't know you, goes for the jugular. looking at the size of him, you think he'd have a really 'wimpy' bark, but no, he outbarks the bigger dogs by decibels!!
Scares the crap out of anyone who doesn't know he's there!! :D:D
