What seats you got planned to go in there?
Right here, right now, no Idea whatsoever?????
nigelr32: How easy are the door cards to remove? The passenger side one on my car has been removed and put back, but it's missed a clip so i need to remove and pop back properly (i did ask Fiat but they said "it's supposed to be like that...") Is it just a case of removing the clip or wire connecting the door handle, then pulling? Does the mirror casing come off first or after? Any help appreciated, I'm sure it's a piece of p**s to do.
Much appreciated, i'll press thanks. I'll give it a go in the morning.The interior trim around the mirror mounting must first be removed. Then there is a plastic trim just behind the interior door handle that has to be removed. (Like a "D" shape). There is an allen bolt behind that trim, and another one just under the interior handle/armrest. Then remove the two screws at the bottom of the panel. You must then pull the panel out away from the door itself, and lift it up off the flange that it hangs on adjacent to the window.
Hope this helps.....
What a Brilliant thread!. Appologies if I've missed it but what are you planning on the engine front?.
Happy new year
Julio
Initially Standard 1368 16v that was originally in the car. Don't really know whats next?? It may end up 8v so I can run a hairy Cam??
I also have Megasquirt2 to go on it at some stage.
1.2 is the best way for more performance and reliability six speed box is fitted to the rally car 130bhp ..cams available from c/b in different lifts..head mods can be done but looking on the guy croft forum reveals that head mods are a pain to do and give little improvement on the 8v [his wording] unless you go all out and do an over bore /high compression pistons head skim to increase the compression and fit cams/4 branch manifold decat exhaust etc in other words ..do the blooming lot.. :devil:
Have you started to fully weld the body yet..? we want pics please..well I do ..![]()
I really want a garage.
I asked jug the same.What he said ++
Wanna go halves in some workshop space?![]()
