Hi I'm after a radio code for my partners fiat 500. It's a blaupunkt
Fiat 312 sb05 s&s
7 648 290 316
815 bp829091616489
Thankyou
Fiat 312 sb05 s&s
7 648 290 316
815 bp829091616489
Thankyou
Fiat 312 sb05 s&s
7 648 290 316
815 bp829091616489
Thankyou
Thanks for donating to the forum.
Your code is: 6453
I have the Radio Blocked / Wait message so I have tried leaving the ignition on but have found out the radio turns off after 20 minutes.
I have now disconnected the radio and hooked it up to a battery charger but it still turn off after 20 minutes. Is there anything else I can try or is the radio a lost cause?
Thanks in advance.
Thanks in advance.
You should be able to switch off the 20 minute mode via the menu button on the radio. Press "MENU" then scroll down to "RADIO OFF" using the up or down arrow. Then use the left or right arrow to change from "20 MIN" to "00 MIN".
Thank you for getting back I touch again Davren. No matter how many times I press menu I can't change the timer.
hello i need the code
SN :BP937227230725
AN: 7649372316
Thx
I wondered if anyone could help me with the m code for my fiat stilo.
Serial NO:M001895
Visteon part NO: 2FCF-18C838-BE
FIAT PART NO:735296997
Chassis NO: 00112936
Thanks!!
Serial NO:M001895
Thanks!!
Hi
I am after the radio code for my Scudo van 55 plate with a fiat radio fitted at manufacture if anyone can help please.
Serial No CL040150999007C Model PU-2294A(C)
Thanks in advance
Its C70000003324 thanks
