Hi everybody,
I bought a used Visteon OD CD Radio (735296997) for my Stilo, unfortunately
without the code.
The serial-No is M019458
Could anyone help me ?
Thank you
Thanks for donating to the forum.
Your code is: 4858
Hi everybody,
without the code.
Thank you
Hi everybody.
I bought a car where is set of radio Blaupunkt Verona C51 and CD changer IDC A09. Radio is working fine, but the changer is asking for a code. Even though the car is not Fiat, searching on google for code brought me here.
So please help me if possible.
P/N 7607769100
S/N BP910014690454
Hi everybody.
P/N 7607769100
S/N BP910014690454
This code does not work for me, I tried it right now. I set code trough numbers for radio stations and then pressed OK button. Any guess?Thanks for donating to the forum.
Your code is: 6621
Thanks a lot Davren, this code worked. I realized that slots 1 - 3 does not accept most of CDs but 4 and 5 work almost well (all original and half of burned).Try 4641
Thanks again.
Hi please could you help out with a code for:
7 645 358 316
735 388 373 0
BP535868142652
Hello Friends of Fiatforum.
I hope that you will be able to help even me for the code of the Connect Nav Plus Magneti Marelli installed on a Fiat Croma 1.9 Emotion year 2006.
The codes are listed on the Connect Nav:
IMEI
500189440289970
735419921
544C2IGBF B03
Thank you in advance for what you can for me.
Good evening.
Enzo
Cordial greetings from Italy.
Hi All,
Would really appreciate some help, switched on the fiat 500 a couple of days back and its randomly asking me for a radio code. I removed the head unit and have the following numbers stamped on the white sticky label:
815 BP829290771936
7 648 292 316
On the actial head unit there are also another set of numbers engraved into the metal - not sure if this is the code as the format appears to be the same as the "7 648....", however the numbers start with "8 635 133...".
hello
please could you help me with a radio code,picked car up on saturday and didn't notice there was no radio code and have just had a new battery fitted !
numbers i could find were :
7 642 374 316
bp237448034608
thanks
andy
