danielson81
Hello all,
A week or so ago I posted about my rear indicator playing up and some nice fellow suggested spraying it with WD40. ((https://www.fiatforum.com/showthread.php?t=46285) )
This worked a treat.... for a few days. Now every few days I have to remove the rear light cover wiggle the bulb around and spray the bulb holder with some more WD40 then its ok for a few more days. Ocassionaly when its very cold in the morning it will misbehave (ie flash intermittently) if its used in the first ten minutes of driving.
However on Friday it didn't work again till the bulb was taken out and put back in again, despite WD40 everywhere! I have changed the bulb several times also.
So, does it sound like there is some moisture getting in, or the acutal bulb holder/contacts is faulty. Do you think replacing it with one from a scrappy might make a difference. The brake light and fog light work fine.
