its fairly easy.
you need two people
step 1, get a ring spanner, its 6 7 or 8mm
2 get a cloth,
3 put spanner on bleed nipple (under battery tray)
4 place cloth over nipple (or a clear pipe going into a bottle would be better).
5 get 2nd peep to push down clutch slowly but consitantly whilst you open nipple, then lock it off.
6 2nd peep hold clutch to the floor until nipple is closed.
7 release clutch pedal
8 repeat steps 5-8 unti you've gone thru a fair amount of fluid (keep topping it up at resivoir, let it get too low and your brakes may fail aswell!!)
clean up, replace everything, see how much firmer the pedal is, two days later, you need to do it again as your slave is ****:bang:
