Technical Seicento 1.4 16v Project
its been done before , as said before search function or start a thread or if you sign up to fiat scotland looks at mings project thread :)
Hey Aaron,
Its been years since you, Emma and her dad completed this modification, but i just finished reading the whole thread today. Its minor to say that you did a fantastic job and looks like it came out of the factory like that! Also, i have a question that doesnt have to do with your sei but with those who have a/c on them. I am from Greece and i am a proud owner of a '02 Seicento Abarth with a/c and power steering as well. I desperately want to do this conversion but because of the hot weather here i dont want to get rid of the a/c. Do you or Emma know or anybody else in the forum if this can happen? Thanks in advance.
Snice, new to these little cars, I moded mine the other day, taken the badges off. Thats it really ! Rearranged the wording of Seicento and got Snice. Think thats what you should put on the back of yours, maybe with a telescope attatched to it so when your blowing doors off, they still see Snice! Mu Hu Ha Ha HA.
El año pasado conseguí un motor completo 1368 16v y una caja de cambios para un proyecto. Se cree que es la primera vez en el Reino Unido que se incorpora este motor a un seicento deportivo.
Para aquellos que no lo saben, este es el mismo motor que se usa en el nuevo camión de bomberos Panda de 100 hp, pero mi motor en particular fue sacado de un stilo con solo 8k en el reloj.
Entonces, desde que compré el motor, poco a poco he ido encontrando las piezas necesarias para que esto funcione. He comprado...
1. Colector de acero inoxidable Supersprint
2. ecu esmeralda
3. Colector de entrada de un Mk1 punto 16v
4. Cuerpo del acelerador de un MK1 punto 16v
5. Aleaciones compomotrices de Mo de 15".
6. Configuración completa de frenos delanteros y traseros del Punto GT.
7. Equipo de inducción.
8. Indicador de temperatura del agua de Raid
9. Indicador de temperatura del aceite de Raid
El plan es convertir el sistema fly by wire al sistema operado por cable, de ahí la necesidad de piezas MK1 punto 1.2 de 16v. Mi papá (Jon) preparó una placa para montar paquetes de bobinas, como se muestra en las fotografías a continuación.
También estamos utilizando la caja de cambios de 6 velocidades y convirtiéndola en una accionada por cable desde hidráulica.
El motor 1.4 está ahí, esa era la parte fácil, pero aún no está conectado (de ahí el desorden jajaja). El desafío será ordenar todos los cables para conectarlos a la ECU esmeralda.
Fotos del progreso hasta el momento.....
La placa del Coche Seicento Abarth 51.
El motor 1368 16v hecho solo 8K
Antes
Motor saliendo 21/01/07
Esta fuera:)
emma.
Buenas tardes, que inyectores de gasolina le as puesto?
