Okay, thanks, I'll order some cables and give it a try.Yes the module is bypassed use the red cable to then plug your OBD multiscan in
As
I dont know if anyone else can help as it seems Rolopolo hasn't been seen for a while. At the start of his thread is a picture if a dimantled glove box/dash. The cable hanging down has obviously been trapped where the front panel screws onto the bracket behind it. Does anybody know what that cable is?Hi,
Anyone found the location of the elusive SGW module?
2020 Ducato,
Currently I’ve all the lower dash removed,
Cannot see anything resembling a module with the two connections of the SGW bypass cable
On my UK 2022 Ducato the SGW is mounted behind the glove box on the left hand side of the vehicle. To get access you need to remove the glove box completely and the SGW is bolted to the back of the glove box panel.I dont know if anyone else can help as it seems Rolopolo hasn't been seen for a while. At the start of his thread is a picture if a dimantled glove box/dash. The cable hanging down has obviously been trapped where the front panel screws onto the bracket behind it. Does anybody know what that cable is?
linknet, Thank youOn my UK 2022 Ducato the SGW is mounted behind the glove box on the left hand side of the vehicle. To get access you need to remove the glove box completely and the SGW is bolted to the back of the glove box panel.
My 2022 Ducato is a Devon Aztec XL so it's a PVC.linknet, Thank you
I have a 2020 Ducato so hopefully if there is one there at all it will be in the same place. I would really like someone with Multescuan to plug into the OBD port and tell me if there is a SWG before I start removing things or ordering from Gendan. Iv'e been asking around at the Warners shows but no luck so far.
Is your Ducato A Motorhome or PVC?
Another reason for my posting is that on the picture at the start of the thread a cable can be seen hanging down that has been pinched between one of the dashboard fixings and slightly damaged. A cable on my van has suffered the same fate at some time in its previous ownership and although I have released it and all seems well I would rather like to know what the cable is for. Any ideas.
Thanks again for your input.
Thanks againMy 2022 Ducato is a Devon Aztec XL so it's a PVC.
That cable looks like an aftermarket addition and although I don't have anything exactly like that I have one cable from the tracker routed through in that corner into the engine compartment which connects to, and immobilises, the starter solenoid. There's also one on the drivers side through into the engine compartment for the alarm siren.
I have Multiecuscan but live in the South East so a long way from you so can't help there.
Removing the glove compartment once you manage to drop down the front cover is relatively easy, just a number of torx screws, and it pulls off towards you with the SGW, if you have one, attached to the back.
Ninja21Hi, I have the 2020 Ducato and want to ask if the SGW on my model is located as some have said on the back side of the glove box passenger side? Thank you Dave.
Yes im fairly certain it does, my van is reg Oct 2020 and i tried a Topdon AD800BT on it recently and it came back with SGW communication errors, I didnt look any further as my friend who has the Topdon at his garage was just about closing up, I will drop the glovebox down and take a look in the very near future to confirm it. Ive already purchased the bypass cable as I want to install the LED daytime running light headlamps as some others have already done.Ninja21
When I contacted Gendan about MultiECUScan and the need for a SWG Module Mike replied that " Being a 2.3 model makes your vehicle an x290 model, not the later x290 MCA (which all use 2.2 litre engines at the moment). We have only encountered SGW modules on the 290 MCA models, so you should be in the clear" but I have yet to try. My 2020 was a July registration so possibly a 2019 chassis
Have you actualy confirmed that your 2020 model has the gateway fitted
Thank you for the reply. iv'e yet to order from Gendan so I would be grateful if you could let me know how you get onYes im fairly certain it does, my van is reg Oct 2020 and i tried a Topdon AD800BT on it recently and it came back with SGW communication errors, I didnt look any further as my friend who has the Topdon at his garage was just about closing up, I will drop the glovebox down and take a look in the very near future to confirm it. Ive already purchased the bypass cable as I want to install the LED daytime running light headlamps as some others have already done.
So would I as my Ducato 2.3 140 was manufactured in Dec 2020.Thank you for the reply. iv'e yet to order from Gendan so I would be grateful if you could let me know how you get on
Ive just had the passenger side glovebox and surrounding housing out and i cant see the secure gateway module anywhere in that location, puzzled now as to where and if my van actually has it, as said before im fairly sure it does but have yet to find it.Thank you for the reply. iv'e yet to order from Gendan so I would be grateful if you could let me know how you get on
I'm in exactly the same same situation. I took my glovebox out and compared it with the OP's photos and I couldn't find the SGW either.Ive just had the passenger side glovebox and surrounding housing out and i cant see the secure gateway module anywhere in that location, puzzled now as to where and if my van actually has it, as said before im fairly sure it does but have yet to find it.
Ninja 21Ive just had the passenger side glovebox and surrounding housing out and i cant see the secure gateway module anywhere in that location, puzzled now as to where and if my van actually has it, as said before im fairly sure it does but have yet to find it.
To be honest as mentioned before I plugged it in and it recorded SGW errors against every module, I will scan it again with the Topdon next week sometime.Ninja 21
Thank you for the update. As I understand it MultiEcuScan identifies that the SWG module is there when first connected. Did your Topdon identify the module or did it just respond to clearing the codes with the communication error. Perhaps the Topdon is just not compatible and returning an erroneous message.
