remove inside door panel, unclip the rods from the door handle, remove 2 screws from outer side of door, handle can now be removed from vehicle, on the back of the handle you will see a notch about half way up the barrel, push a screwdriver into the notch and slide barrel out the front. To replace simply push the new barrel into place and reverse above.
