officina_crane
- Joined
- Sep 15, 2006
- Messages
- 61
Ring day-cruise lights. thoughts? hit me!
Take it the idea is with them you drive around with them on instead of fogs? what will PC Plod think?
like a delinquent chavvy [email protected] who can't even wire in a set of fogs properly - they should only come on with sidelights & turn off when main beam is on,
IIRC these are not Fog lamps but LED running lamps/ position lamps As per what is fitted on a HGV/ motorhomes...... and they are "E" marked as such so long as teh are mounted correctly they are legal to be used all the time as per side lights
Yea i guess so, however the plod might not see it like that, and can easily use it as an excuse to pull you and inspect everything about you and your car.
I also have a pet hate of foglights when there is no fog even vaguely insight. but i'd like to point out they are not fog lights and have no where near the same intensity as fog lights. they're bright enough to be seen. but not bright enough to dazzle other drivers. they essentially act as sidelights. i also have them aimed slightly lower than the recommendation, just to make sure!
anyone seen a similar thing on the new audis? they are designed as fog lights and are insanely bright, yet anyone who has them seems to have them on. they are on the new R8 and the new audi A7 coupe. painful on the eyes.
