Technical rear caliper?
Glasgow
Hey Peeps,
Need some help here, i'll got no idea how would i go about checking.
Could someone check if alfa 156 (X-reg) rear caliper would do fine on our cento ?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=200432725357&_trksid=p2759.l1259
Or how would i find out?
I'll found the list of caliper that fit:
ALFA ROMEO / Alfa 145 / 1.4 (96-2001)
ALFA ROMEO / Alfa 145 / 1.6 (96-98)
ALFA ROMEO / Alfa 145 / 1.6 TS (97-2001)
ALFA ROMEO / Alfa 145 / 1.7 16v (96-98)
ALFA ROMEO / Alfa 145 / 1.8 TS (97-2001)
ALFA ROMEO / Alfa 145 / 1.9 TD (96-2001)
ALFA ROMEO / Alfa 145 / 2.0 (95-2001)
ALFA ROMEO / Alfa 146 / 1.4 (96-2001)
ALFA ROMEO / Alfa 146 / 1.6 (96-98)
ALFA ROMEO / Alfa 146 / 1.6 TS (97-2001)
ALFA ROMEO / Alfa 146 / 1.7 16v (96-98)
ALFA ROMEO / Alfa 146 / 1.8 TS (97-2001)
ALFA ROMEO / Alfa 146 / 1.9 TD (96-2001)
ALFA ROMEO / Alfa 146 / 2.0 (95-2001)
ALFA ROMEO / GTV / 2.0 (96-)
ALFA ROMEO / GTV / 2.0 Turbo (97-)
ALFA ROMEO / Spider / 2.0 TS (95-)
ALFA ROMEO / Spider / 2.0 Turbo (97-)
FIAT / Barchetta / 1.8 (99-)
FIAT / Brava/Bravo / 2.0 (97-2002)
FIAT / Coupe / 2.0 20v (96-2000)
FIAT / Marea / 1.8 (97-2000)
FIAT / Marea / 2.0 (97-2002)
FIAT / Marea / 2.4 TD (97-2000)
FIAT / Marea Weekend / 1.8 (97-2001)
FIAT / Marea Weekend / 2.0 (97-2001)
FIAT / Marea Weekend / 2.4 TD (97-2001)
FIAT / Punto / 1.4 Turbo (97-99)
FIAT / Punto / 1.6 (97-99)
FIAT / Punto / 1.7 TD (97-99)
LANCIA / Delta / 1.6 (97-2000)
LANCIA / Delta / 1.8 (97-2000)
LANCIA / Delta / 1.8 (97-99)
LANCIA / Delta / 1.8 LS (98-2000)
LANCIA / Delta / 2.0 (96-2000)
LANCIA / Delta / 2.0 Turbo (96-2000)
But 156 is not in it, just want confirmation.
Ming
Yes it fits exact ones i run
bleed nipple taps the inner arch so you need to tap the arch in a tad just the flappy bit. never done any major damage to mine. you can see a light scratch just above the calliper.
the marea i got it of is on the list, a 2.4 td weekend estate.
i got the brackets from a guy on here they worked perfectly but with they were 0.5 -1mm thicker. dont know who though.
155 calipers do fit, theres a list in the guides of calipers.
Just found some GTV ones from a 99, but list states up to 97, does this mean that they changed them and won't be completely plug and play?
Also i'm guessing they will be 240mm as that is what i'm after.
Im running coupe 20valve ones
hey cc1 what paint you using on those calipers?
