Quick Question thread
Status
Not open for further replies.
Whats an easy way to calculate the change in compression ratio when adding a decomp plate? we are talking 16v, not 8v.
you need to know-
current compression ratio
current cylinder volume
diameter of cylinder
thickness of decomp plate
lets use an imaginary example
current compression ratio is 10:1
current cyl vol is 500cc
diameter of cylinder is 100mm
decomp plate is 2mm
first you work out the volume that is left when the piston is at TDC.
10:1 by 500cc = 50cc
now work out the extra cylinder volume created by the decomp plate.
= area of cylinder in mm2 X height of decomp plate in mm
area of clyinder = pie X radius2 = 7853.982mm2
X2mm = 15707.964mm3 = 15.7cm3
now we know the increase in cylinder volume we can calculate the new compression ratio
500+15.7 : 50
becomes 51.57 : 5
becomes 10.314 : 1
easy as that :)
or go buy some proper buckets.
do i buy two mgb engines and gearboxes on ebay which have been left in a field for 5 years!! for 99p just to take apart and reassemble for experience, also to play around with (mods) bearing in mind they'll probably never be run again but may prove usefull for parts if i do get an mgb....?
yay or nay?
Status
