This is my 1972 seat
I have been fortunate that the flywheel is in great condition . The rivets were only worn through on the pressure plate side .Unless already fitted a light flywheel skim may be advisable if rivets have scored flywheel as well as old pressure, unless of course you were lucky.
Reason being it reduces clutch contact area until worn in to match grooves, a bit like brake discs.
Quite liked the Seat versions saloon and coupe, as an apprentice they were popular in early 70s around our way.![]()
All that effort should be now repaid with a fun little car to drive. I always liked then when several came in as an apprentice in early 70s.And finally installed the engine and gearbox .
Pretty straight forward. I had them on a trolley which I wheeled into place and jacked up from underneath.
Fitted the rear valance with rear center mount first , then moved the jack to the rear of the gearbox end and bolted in the other two mounts .
Connected cables , wiring and plumbing , did a quick start test and put some coolant in.
Now it’s time to test
Timing will be adjustment after roadtest as it was built in the days of leaded fuel, not the rubbish we get today.So the seat drove ok , no issues. Everything works as it should . Gears are great . Clutch was ok , gave it a slight adjustment (one turn) and locked it off again.
I think I’ll have a Quick Look at the timing and double check ignition , points and such to see if everything is as it should be.
Personally I prefer points and condensor, a lot easier to fix at the side of the road and much cheaper.A few more shots and some AI dabbling , also found this shot of a competition car from the past .
Had a misfire develope into starting trouble .
After a bit of back and forth it was the new condenser .
Replaced it and she fired straight up , will get one of those competition condensers which everyone says are the nuts … or will look at an electronic ignition kit.
Money on no chance LOL.
Never used an electric car heater, does dynamo cope?
If stationary, is that a bit like leaving a valve radio on whilst doing a bit of "courting" from a long distant memory, killing the battery.Money on no chance LOL
and then finding the coil is burnt out because you had to have the ignition on to feed power to the radio and the points were closed!If stationary, is that a bit like leaving a valve radio on whilst doing a bit of "courting" from a long distant memory, killing the battery.![]()
Any excuse would do....If stationary, is that a bit like leaving a valve radio on whilst doing a bit of "courting" from a long distant memory, killing the battery.![]()
