Panda (Classic)  Project Fallout
let me introduce to you, the free panda 4x4 which was first spotted >>Here<<.
First off however, here is the plan:
i will (some how) make the panda look "Post Apocalyptic" yet keep it in a road legal state (so no spikes, sharp rusty edges sadly). We have all seen mad max right? all wanted to replicate a mad max style car?
well let me be the first to attempt this with a fiat panda 4x4.
if anyone here has seen the TV program "Defiance", you surely have seen the epic Doge Charger that looks post apocalyptic. i will be trying to aim for the same theme. with such things as an external roll cadge, external metal mesh / grills covering the windows, custom bull bar, reinforced rear bumper made from tubular metal, custom twin output exhaust, and many many more.
this project is going to be undertaken as cheaply as possible (excluding parts necessary for a safe road going vehicle). reusing as many things as i can find (in scrap yards, freebees), true to a real post apocalyptic constructed vehicle. i will also be taking the "rough is best look" (please note, i say Rough not Rat!) the panda its self of course will undergo all the rust prevention Talon went under when i got him.
anyway, i will leave you a few seconds to build up a mental picture of how a panda 4x4 could look in a post apocalyptic landscape while browsing some of these Pictures.......
ok.. that should do.
First off. i need to get the panda all well and good.
a few things are broken... the exhaust, the front suspension on the passenger side, both rear dampeners are rusted out, the doors are shot but i will try to fix them, the gear stick is really loose and all the roller bearings have dropped out, the wiring is a mess (mice attack!), there are no brakes.. and i mean no brakes, and lets not forget the underside rust.
so today i started by stripping out everything inside the car to get a good look at the floor pan and clean it all out (Dragon Man style!) i found the usual rust: the boot floor is a mess, but easy fixable, a seam has gone just behind the drivers seat anything forward of that seems to be OK, and the back of the sills are just gone so i will need to rebuild that.
the engine runs.. the vac advance line has split so its a bit rough on tickover but it seems good. the fuel tank seems good.. all the 4x4 stuff seems good.
i have go a few pictures took free by a professional photographer! (or should i say someone with an epic camera :p)
Here are a few picture, but please check out >This Album<
like i say, check out the photo album.
i will be keeping >Online video logs< of this, so keep a look out on Youtube too.
here are some videos, both are long but the second one is longer!
Project Fallout a panda 4x4 turned post apocalyiptic - YouTube
Project Fallout Panda 4x4 What to do Post Apocaliptic looking Panda! - YouTube
keep watching guys.. the jet wash will be coming out later today!
Edit:
This is how it looks now: :eek::eek::eek: :slayer::slayer::slayer:
no... i dont think it will for a while. for now i will have to find other ways of getting the engine to run.
im keeping on the look out for anything that can help me with the ECU though. sadly no one re-programs multi injector ECU's.. not sure why.
if i could find someone with a chip reader i could do it.
Maybe you've found a niche in the market to fill . . .
new video guys..
i also found out how to fix the annoying leak from the speedo drive on our panda gearboxes
check the video out for a bit of a talk about it, and how to fix it!. firstcar-Y10
{{Edit}}
that video messed up. for some reason i had no audio on it?! anyway im going to have to remake the whole damn video again.
to fix the speedo drive you have to undo the little alen key bolt from the side where the speedo drive is, and use something like some long nose mould grips to clamp onto the threads (low down on the threads) the speedo cable screws onto.. then leaver it out by pressing down on the mould grips.. the whole thing you screw the speedo cable on will come out of the gearbox along with the plastic gear that picks up the speed from the front diff.
on the shaft theres a little rubber washer, that will need replacing... replace that and no more leaks from the speedo drive :D
that is how you fix it!
Yep, I'd got that far, but whenever I try to replace the spindle with the new O ring on, the hole for the fixing screw takes a chunk of rubber out the side of the new ring. Maybe I just need a slightly thinner O ring, I was looking for a reasonably tight fit.
theres another o ring inside on the plastic spindle.. that is the one i find that passes..
besides, the outer O ring does not go down far enough to get damaged by the fixing bolt hole..???
the one on mine does not...
This O ring: (on the white spindle)
This hole:
Don't know if yours is different?
mine is the same.. but it does not chew up the washer.. id file it out..
fallouts engine is all wired up! i am using the 6F ECU from off a 899/903cc cinquecento (no immobiliser)
i have but one setback.. the fuel pump.
theres no way in hell i can fit it in the panda's tank.. its just too big.
does anyone know of a car (one that i can find in the scrap yard) that has a high pressure in line fuel pump?
theres no way im spending anything more than £20 on a fuel pump and even at that i will be looking for a cheaper way to get one.
it sux how everything is in tank now days :(
just found out that the ford sierra 2L has an inline fuel pump rated at 4 bar!
its a bit high.. but i think it will run this engine great!
if i can plumb it into the original fuel system i will be laughing!
im going to collect it tomorrow.. free of charge too! :D
i may have to uprate the pandas original fuel lines though.. im not sure what pressure they can withstand..
i'll also have to look into where to put the fuel pump.. my guess is that it will not like to suck air, so i think i'd have to put it low down.
will have to see.
will have to see.
I'm so jealous that you have a scrapyard near you that keeps older cars, every one I can find only keeps newish cars for any length of time before they are cubed :(
