Currymunster
- Joined
- Apr 19, 2020
- Messages
- 115
- Points
- 28
It does look the same. It looks exactly the same. That's a bit strange.
Here is a picture with part of the spare one I have, the inside bearing on the shaft. I got this column to use the sensor, but it was not working in the end, was even worse than the broken one I had (the computer and little motor are good). I bought a new one and it works very good. But my column is exactly the same size as this other one.
I mesured again and the bearing's sizes are the ones I put earlier.
The chassis/body is the same, 188.
That looks like the gear in contact with the pump/motor with the bit that attaches to the steering universal joint rod.
The bearing I'm after is the one right at the top of the column where the steering wheel attaches.
I'll get a pic on here.
