Hello,
My passenger door mirror has stopped working when I try to adjust it from the driver door control.
Driver side mirror is working ok.
What I have done;
1. Removed the pax mirror connector and with a multimeter checked the pins. There are 4 pins which go to 12v when the adjuster is pressed in one of the directions.
I understand this is a 'dirty' test as the mirror unit has 2 motors and I'm only testing a single pin at a time.
But this shows something is being sent/happening on 4 pins at some point in pressing the adjustor pad.
2. I then removed the pax mirror unit and plugged it into the drivers side - and it WORKS!
So I am assuming the mirror motor unit is working as expected.
So what is wrong?
4 pins on the connector are receiving 12v at some point in pressing the adjuster in one of the 4 directions.
But something isn't working correctly/somewhere to send the correct combination of voltage or a signal it needs to mirror (
) the presses on the adjustor pad.
Next I wanted to look at the connector between body & door - but I don't know how to disconnect it - can anybody tell me the correct way so I don't end up with a broken connector?
Suggestions for what to look at/test next very welcome.
Thanks,
Mark
What I have done;
So what is wrong?
Thanks,
Mark
