Well so far I've not suffered from 'dodgy electrics' as such but other design flaws that have affected the electrics in some way;
Rear wash wipe water feed tube failing in the body to rear hatch rubber tube then the water running down the loom straight to the rear left light cluster connector causing a short, meltage of plastics around connectors, all sorts of bulb illuminations and as previous owner seemed to use strong screenwash fluid, everthing was a nice blue and tracks in bulb holder oxidising nicely.
Loom wires breaking in the same body to rear hatch rubber tube causing random behaviour of rear wiper, tailgate sensor and demister. (demister also has 3 failed tracks
The rear right light cluster seal water leak caused the connector to melt but the major issue here was the ingress of water that made its way into the boot, along the right hand side at the base of the inner wheel arch and down into the passenger footwell forming a lake. Obviously it was then absorbed by the sound deadening material stuck to the back of the interior carpet which because permenantly wet and then spread various quantities around. The sound deadening material in the drivers footwell right upto the firewall was wet/damp. Once I had the interior stripped upto the dash it sat for 3 weeks drying out.
Only really because I produce technical documentation aswell and believe in producing a quality document which is highly accurate, covers all versions/options and 100% usable.
There was water in an area of the car rather than it being full of water. This area luckily did not have any wiring in it.
If only life was as simple as just 3 wires.
