Technical Passenger door adjustment
Seg10538
Hi all just got my Barchetta in to have passenger door replaced, the guys have hung the door but needs final adjustment on top hinge ? Does the dash have to be removed to get to the back of the hinge ?????
Looking at the tech manual you do need to remove the dash cover and mid range speaker to access the hinge bolts.
Thanks for the quick reply, even my fiat specialist doesn't fancy doing that ! It would seem that the hinge welded to the new door is in a slightly different place, where can I get a hold of a drawing to locate the dash screws please ?
Image from manual attached.
You don't need to remove the whole dashboard, only the body coloured sections which have obvious bolt heads on them.
I think anyway, that's how the manual reads.
