About to adjust the clutch on the Barchetta, I have looked at the workshop manual but I have to admit that the process is a bit 'one eyed' I can see that the adjstment is 125mm plus/minus 5 mm. Howevermaking the measurement is crazy in relation to the fact that you have to have the clutch at rest and depressed, impossible of course. Also the clutch pedal to floor when fally depressed would be useful/essential to know. I think the only way to make a stab at this is to measure front of depressed pedal to floor and add this to the 125mm when measuring from floor to raised pedal, e.g. 30 mm plus 135mm e.g. 155 mm total, and adjusting the clutch to recommended distance by removing the 30mm and adjusting out the difference. Also did you remove the battery and tray to ease access
