Technical  Panda throttle / accelerator issue (cable?)
zippeyrude
Ive noticed that the first part of pressing the accelerator pedal doesnt do anything to the revs / engine. After, perhaps, a centimetre of pedal, the car revs increase (as the should).
I initially thought the car (2005 4x4 1.2 petrol) was rally slow, but im finding that there seems to be a slack area in terms of pedal response.
Could this ve a throttle cable issue, where it can be tightened perhaps - or the throttle adjusted somehow?
Or does the panda have electronic wizardry and an electronic throttle position sensor?
Any ideas?
Might not have a cable depends on the year and the engine fitted. I have a 2004 Dynamic 1200 8 valve which is cable operated but later models were ( Fly by wire) which is an aeronautical term but used frequently in the automotive industry
Flyby wire normally
Throttle bodies on the 4x4 are unique and hard to come by
Before jumping I think we need some data
Throttle opening and throttle pedal can plotted on a scan tool
Does it rev okay in neutral
Flyby wire normally
The revving is fine I'm both neutral and in gear. Just the first part, say one centimetre, doesn't seem to do anything. No change in revs.
Only when accelerator is pressed more than this does the engine rev.
So it revs normally
I have not got my car here at the moment. But 10mm sounds about right
I have never measured how much free movement there is, there a bit as you can gently tap the pedal to the radio without the revs rising. 10mm was the normal amount of freeplay on older car cars
ive 3 pandas (including this one), the other 2 are 'normal', this one has excessive play on the pedal - i checked again and its probably over an inch. The feel is definitely wrong on this.
I checked and there is no cable, its all electronic. So i need to check Throttle position readings with MECUscan etc.
Im wondering if there is a motor fault or pedal position sensor issue? Or any play.
It's gone from 10mm to 25mm
The throttle body has feedback it can't be wrong and not flag an engine error
If it was faulty it would be very hard to find a replacement almost impossible
The pedal is a standard 46800473 so easily replaced
It may be fitted with two, three or four nuts as Fiat saw fit on the assembly line
You may not need a new one. The throttle pedal can be calibrates via software, I don't know if it can be done with MultiEcuScan or not
First thing to do would be to scan the live data, it will not go from 0-100 as you would expect and depends what software is used torque I think max out in the 70% range
Yeah 10mm was an underestimate.
I scanned with a basic odb reader, no error codes but I couldn't read throttle position, no option
I'll need to dig out mecus
A £5 Bluetooth elm327 and Torque lite or
Car scanner work fine for this on an android phone
IPhones need a different dongle so slightly. More expensive
If one of your other cars is flyby wire you could always just swap the pedals over
The nuts are on a long stud so you need a long reach socket,
I've one of the blue bluetooth dongles, with torque pro android app. It didn't give me tps option.
I'll need to check the other pandas...
Using a
And Torque a couple of days ago on a flyby wire panda, to read throttle pedal while driving
Not got the car here at the moment but this is what I was reading while driving
F/T fuel trim is useful and missing from multiecuscan, as you accrlerate it goes slightly positive and coast negative but stay roughly towards the bottom
