Technical  Throttle Sticking
Triops
Lynton
Sometimes revs stay high with foot off the throttle. Also slow to return to idle. Switch off and back on seems to sort it. Foot pedal feels free enough. Any ideas?
Model
1.2 petrol Panda
Year
2008
Mileage
63000
Cable throttle or fly by wire?
Have you tried cleaning throttle body, IACV and MAP?
Cable. Throttle cable free and the plate opens and shuts without problems as viewed with air cleaner box off. Lubricated the circular valve where it is located in the throttle body. Also pulled a little plug off the throttle body and cleaned with contact cleaner.
What is the IACV and MAP?
Lots of different causes
What is the exact symptoms
Intermittent
Hard fault
Starts.high and stay high
Start low and sticks high after the pedal push
Fails when hot
Fails when cold
Hunting up and down
And so on
Idle control valve icv
Oil on MAP sensor causes.irratic idle, rarely pegged high though
Intermittent
Hard fault
Fails when hot
Fails when cold
Hunting up and down
And so on
The problem is intermittent never when cold. Car always starts well. Air filter clear , air box connection rubbers good. The throttle cable is moving cleanly and returns without problems to its stop position.
So sometimes when I rev to say 3000 rpm and clutch in to change gear the revs don’t drop. Flicking the accelerator doesn’t help.
It sometimes slowly returns to lower rpm if I start going uphill .
If I stop and turn off for 30 secs then start again it clears it. I.e it doesn’t race straight up to 3000 rpm.
I will find the MAF sensor and clean with MAF fluid I already have.
That’s about all I can tell you atm.
There's no MAF only MAP
It's to the right of the throttle body
On the black inlet manifold
I doubt it's the problem, but it's worth cleaning snyway
I will do this. Just been out in the car … running sweetly…. Even when hot.
Thanks for your help
Intermittent
Only when hot
Doesn't clear unless you switch off for 30s
Doesn't clear by flicking the pedal
If you have a scantool
You could.look at expected rpm Vs actual
Throttle angle
Icv steps
Inlet manifold pressure
But it's not something that rings any bells
Been doing it again. When it does it the revs rise to 3000 rpm sit there for 5 secs then return down to normal. Occasionally blipping the throttle sorts it when it’s such, Sometimes not. I guess it’s a sensor. Will put a diagnostic OBD reader on it. Will clean the inlet manifold sensor as well. Then it’s off to my car man.
While you're looking at the usual suspects (MAP sensor, airbox pipe, inlet manifold air leaks, throttle body, etc.) spare a few seconds to check the ECU plugs are properly seated and the nut holding the small earth lead on the ECU is tight.
Have seen similar symptoms from loose ECU plug and/or earth a couple of times now, usually after someone changes the slave cylinder.
