and you just made up the bit about the op's car and the 'sewing machine.'.. ??
Must have been talking to electrician huh ? - contagious
"I hadnt a clue and rang fiat after buggering about for 4 hours without a clue..
Then called into a auto electrical engineer in my neck of the woods in durham.
he said straight away what the problem was as he had done 3 other panda's before.
my panda is now back to normal
Four hours labour for £60!
Where is this place?
I wouldn't mind them looking at something for me at that price.
Diagnosed straight away, the OP left the car for the day, which is common.
It's a 1.1 Eco, so the sewing machine quote was incorrect, sewing machines run a lot rougher.
200 miles later and the occasional misfire is back. My suspicions confirmed as I feared. Software update was a con - probably well intentioned - but nevertheless a waste of money.
Sounds like a con job to me - total BS...
Probably a loose connection thats all.
WHY didnt you take it to someone with diagnostic equipment instead of buggering around with changing things and back street rip off merchants ?
There are NO 'brittle' wires and 'hidden' connectors etc etc - utter, total crap.
You have been well and truly conned. Wanna buy some dehydrated water ??
Perhaps you want to reconsider this view? Person who got wiring sorted is fine, person with update isn't, funny that.
It's good to know that there are competent people on this forum such as T14086. I have had an intermittent P0202 on a 2010 Panda 1.1. I have swapped injector 2 with injector 1 and still got a P0202. Having checked the circuit diagram I found that all 4 injectors and both ignition coils have a common ground that goes back to Connector D0004 Pin F. There is only 1 wire (brown/black) at D004 Pin F and so there had to be a join somewhere along the loom. Thanks to T14086 I now know where ground wires are joined in the loom.What the OP is trying to describe is a 'splice-joint' which is located in the engine harness near the rear ignition coil.
This has been known to myself and other Fiat techs for years so it's nothing new and it's likely the auto electrician phoned dealer for advice, I take around 5-8 phone calls per day from other garages so lets not slag of the dealer techs, dealerships pay their wages not Fiat.
Anyway re-soldering the crimp connection often works but not all the time and the best bet is to replace engine loom at around £135 which isn't expensive (cost of 2 branded tryes) and takes about an hour.
Errors? yes you often get an injector or a random misfire error this is due to the splice joint powering the coils/injectors and a couple of near by sensors.
Hope that has cleared things up.
Hello I have two euro 5s with ecu facing upwards not the ecu that was side on near battery. They have intermittent misfire 2&3 cylinder. I also have done all the basics and the older model 2007-2010 the small injector loom was the problem...my question is on the later euro 5 model with ecm above end of cam cover does this also suffer with a similar issue?
