Technical  Crunching noise 1.1 eco
hodgy18
Established member
Evening
Got a crunchy noise coming from the front end. Sounds like something crunching as opose to grinding. Checked brakes and pads, and there clean.
Could it be a wheel bearing? Anyone else had a similar noise?
It's a 59 reg on 101k miles.
We not a lot to go on
A video would be good
Does it alter with road speed
Does it alter with engine RPM
Does it alter clutch up Vs clutch down
Does it alter with gear or neutral
Does it alter with the Aircon if you have it
Does it alter with blower speed
Is it from the front left or right
Does it do it from cold
Does the noise alter if you dab the brakes
Nothing in the list above. Happens when on the move. More noticeable at low speeds and comes from passenger side.
Did you actually take the pads out
Stone between the back plate and disk
Any play in the bearing
Any noise if you lift the wheel and spine the wheel
Does it alter if you turn left or right
