Technical  Panda 2010
Tuppence1967
Halstead
When I put the right indicator on and then press brake pedal which causes the indicator to flash faster and when I take foot off the brake it goes back to flashing normally. Changed bulbs. Had anyone got a picture of where yhe earth points are in boot of car
common problem with the rear light cluster
repair yourself or will you be going the garage
max 1/2 hour repair
max 1/2 hour repair
need to go back and do the contacts properly , The connector comes apart. The heat from the arcing will have distorted it out of shape
the flat contacts on the cluster itself will be pitted and will also need scraping with a small screwdriver
You dont need to look any further. There is a bad contact with the centre black wire
worse case, an auto electrician would cut the one connector off and crimp a new one on using these
far better than splicing in a new connector and heat shrinking the join. There's some serious amps running down there and I wouldn't want anything hidden accidentally shorting out
