Technical Panda Cross 2010 Fuse Box
I am trying to confirm connections to the main under bonnet fuse box but have been unable to find a match on the elearn site for the wires actually installed any ideas?
Many thanks in advance.
Model
Fiat Panda 169 Cross 1.3 Diesel
Year
2010
Mileage
98000
inconclusive
And to be diagnostic it does have to be while it's failing
But at least we have one reference as a starting place
While the yellow arrow should be over 200 rpm
The red arrow should be over 300 bar 4351 psi
Unfortunately with the quick start there's only two data points
Probably better graphing as bad to get the scale better or graph one above each other so the auto scale does not effect the results
inconclusive
The one I did this morning (which took longer to start), the engine was cold and I saw 315 ish bar and 198 ish rpm. Not sure I've ever seen over 200rpm cranking.
I've bought the Torque app but when I scroll through parameters to record it looks like the vast majority are not available.
inconclusive
Looking at the Car Scanner app which seems to have a much better way of recording and then displaying the results that Torque.
With regards initial setup the Panda isn't listed. It says "select basic OBD-II / EOBD which shows only basic OBD-II sensors if your car isn't listed" will this display enough information?.
Yes
I use both, both are fine on my phone, although on a petrol panda
Also look at the MAF airflow
There is a vacuum operated flap that shuts of the air it stop the engine running on
I can't remember good and bad values but there's about a 30% difference, if it sticks closed
Normally just needs a clean, not replacement
Downloaded and attempted recording with the Car Scanner app. Display of fuel pressure and rpm doesn't seem to start until engine running so not much use! Looked through the app guides online but not found anything obvious to help - any ideas?
Where is this vacuum operated flap, can see a description of it.
There's lots of reasons for random none start
A high percentage are fuel related, mostly due to the filter sucking in air, HP pump seals gone or worn, or not turning fast enough to make the pressure to atomize the fuel properly, with a few EGR thrown in when the engine is cold
Which is why with an intermittent fault it's important to get a snapshot of some data as it's failing
As in the video above the clue was in the MAF reading which lead to a repair that didn't require any new parts, although an unusual fault I can guarantee most people would have thrown a lot of unnecessary parts at it first
Taking a scattered gun approach can get expensive it's not unknown for several pumps, turbos, injectors to be changed and the original fault to persist
Car scanner and torque both record data from ignition on my petrol panda
Here's an example of mine
Ignition on, cranking and idling
Car scanner
Around 5 samples per second isn't great but adequate for most faults to show
Car scanner
Unfortunately I have yet to actually record the thing misbehaving. I thought Car Scanner was all primed and doing it's stuff until I actually looked at the recording - it would have been the ideal occasion as it took a good few seconds to go and has a little half-hearted attemp to start in the middle too - just like on that youtube video. Next restart it went straight away, and the one after that. I've seen no issues with pump pressure, pretty much straight up - unless there's an issue with Intermittent pressure regulation, I can't see it being the hp pump. Cranking speed always sounds about the same but sometimes it fires up straight away, sometimes not 🙄
At long last I have caught it in the act. Wouldn't start yesterday and I had my code reader in the car (Icarsoft CRPro). It doesn't do graphs but I recorded the readings of the Battery Voltage, Engine Speed, Diesel Pressure and Air Mass. Note intermittent Engine Speed and Air Mass coupled with fluctuating fuel pressure. I have had a couple of issues with the car not seeing the MAF sensor (which is a new Bosch one).
  • Panda 08-08.pdf
Out and about at the moment, tried a few times
But can only see a blank page unfortunately
I have also checked through the other control units for stored codes and there are more;
C1003 Intermittent - Vehicle speed (from CAN).
C1004 Intermittent - Alternator
Doesn't make sense
You can't have 0 RPM and 176 bar
Then 187 RPM and 56 bar in the next frame
It's unlikely both RPM and fuel pressure are out
Looks more like a diagnostice logging issue to me
Doesn't make sense
The way I read it is that the fuel pressure regulator is being commanded (or not as the case may be) causing the fluctuating fuel pressure. The rpm is obviously related. The logging is fine normally, this is only the second occasion of catching it not starting. I wasn't recording the first but noticed the fuel pressure fluctuating, unfortunately I wasn't taking notice of the rpm.
What can cause loss of rpm signal - if it's only the crankshaft sensor or wiring would thus also cause the fuel pressure to be commanded low? The starter motor was cranking fine so can't see engine earth being an issue.
Way I read it you have
Air mass all over the places
RPM all over the place
Fuel pressure all over the place
You can't have 2553 psi from a mechanical pump at 0 rpm
Go back to where you posted this
Everything is logging and graphing correctly
But it started OK on this occasion! RPM is not all over the place, the sensing of it is intermittent! Fuel pressure control appears to be fluctuating, Air mass sensing intermittent!
Can't see it being Crankshaft sensor, car has just done 4hr journey without missing a beat and started normally on 3 occasions. Attitude of car seems to make a difference. When it wouldn't start the other day, and difficulty starting the following, the car was nose down.
So where does this information come from? - ECU. Why should it be intermittent? I have no idea - do you?
I will be your scan tool, use something known to work
Mg per injection is not a normal measurement
I understand kg per hour, theres no way I am going to convert this
My scan tool is known to work, you just don't seem to be able to extrapolate what it's telling you! Thanks for your input but it's been no help at all.
