Oscar the Auris
Toyota Auris Touring Sports 1.2T VVT-iW Business edition TSS
So after 3 years I've finally replaced the Mazda. Leisure lounge regulars will probably be aware of all the malice and aforethought that went into buying a Toyota.
Short version...I've got another baby on the way, the C3 isn't big enough, the wife doesn't want to sell it so I wanted something that did the job I could buy without disappearing down a finance wormhole. I'm aware it will not be to everyone...or perhaps even anyone's taste but this is how it looks day 1 pre-baby damage.
As you can see it's a small Estate...with up to 670l of boot space if you stack to the Roof or 530 under the tonneau.
The interior has aged very well for a car that's nearly 8 and most of the way to 80k.
This picture is mainly because look rear courtesy lights!...the amount of cursing the lack of these causes in the C3.
It has most modcons, so climate control, cruise control, the satnav does allow full post codes (I feared it didn't so isn't as terrible as expected now I've figured it out) and heated seats.
Also 7 airbags and all the modern safety gear...with off buttons as it's pre-2017.
Finally the physically biggest 1.2 I think I've ever seen... compared to the C3 it seems twice the size but in theory they do the same thing and produce about the same power.
Clearly has a water to air intercooler...why it's mounted there god knows. Also yes they don't clean under the bonnet so job for me.
Edit: since posting this done some research it literally has 2 cooling systems (note 2 caps) one is for the engine with a standard pump and the other is for intercooler and the turbo with an electric pump.
Generally presents as a tidy and honest car, one small issue so far..think it needs a TPMS battery. Interestingly it was first registered to Vehicle distribution centre Burnaston, so Toyota owned it for 6 months and then the previous owner to me had it from May 2017, so I'm only the 2nd private owner.
Oh and my son named it immediately.
Future plans are mainly along the lines of beating it to death...although it may be getting 4 new boots to switch to all seasons.
Edited to add on these...
First..I was expecting maybe late 30s early 40s fuel economy. The C3 manages late 40s on a run so this is a surprise.
It's 1400kg so not light at all but it is very slippery in terms of drag apparently and 6th has you just over 2k rpm at 70.
Oh and it's first family duty..to the beach so it's now full of sand, sandwich crumbs and Doritos bits. Nice while it lasted..
the Allegro was not a bad car to drive it was actually decent and reliable. Apart from terminal rot of sills floor fuel tank and axle mounts and suspension that needed constant pumping up it was a decent runabout. Oh and the way it got rid of oil was off the scale. I never did work out where it went to
Not forgetting looks that Even a mother would have a hard time with, and the square steering wheel on the earlier ones and aside from all those things and your list of problems….. it wasn’t a bad car 😂🤣😅🤣
To be fair I think you made the right call, i know we talked about other options but the VAG cars can be expensive these Toyotas are under valued and if you only want to throw mud Children and all manner of crap in them, and do that till the thing dies then you want to do that as cheaply and efficiently as possible. It will be interesting to see what replaces the C3
I sent you a nice Leon FR ST 1.4t on a 66 plate if memory serves.
I'm sure it would have been great but it was 12 grand and change...then whatever it cost to get it into a condition I'm happy with, tyres, service, brakes, timing belt etc.
It had a similar black, on grey, on black on charcoal interior. Boot space wise they are slightly bigger seats up but smaller seats down which suggests the rear seat itself is closer to the fronts.
It would have absolutely done me...and had android auto but I just wouldn't have got the extra 30% of value out of it I don't think as already it would have been more expensive to run at a baseline level even before we get to relative likelihood of one or the other breaking.
At this point I really need to convince the wife we need a new Panda to replace the C3 I think...I want one anyway. It's too small to be an only car but for commuting should be canny.
I would have thought the new panda is going to be pretty much the same size as the C3 you have now ?
It is, but when I was originally car shopping I was going to be replacing one car with one car. Now we've got 2 cars again smaller cars are back on the table for none child related things.
Also if I'm shopping in 2 or 3 years should be some nearly new used ones kicking about.
So having been entirely transparent as to why I have this today was the big day...no the baby isn't coming until next year.
But the child seat arrived...so we can test if it fits. Now modern car seats don't appear to be designed to fit in cars...so this is not always guaranteed.
Success... ignore the mud at the bottom, this is normally the lads side..but he'll be moving, it even spins.
Now if we didn't need a seat that spins it would be half the bloody size...but hey it fits and I fit in the seat in front of it.
No one mention that without the extra height and length of the spinning base it would have fitted much easier.
I will say we haven't bought this..like most of the best most expensive baby gear it's only useful for less than 18 months so my wife's work colleague is loaning us it. Our smaller one which works with our travel system is in the loft...and my wife has decided not to use it.
Once we're out of babe in arms stage this will be getting replaced asap...the seat not the car.
  • Like
Reactions: SB1500
So this is not an update as I've updated nowt...
But did a full multi trip day out in it yesterday actually the first proper run out it's had since it's been all sorted.
Most of my longer distance seat time in this was while it had unbalanced wheels, and or knackered alignment and the poundshop tyres on it. Since the new tyres in November it's done 1k miles mainly round the village or to the shops etc.
Yesterday it got 2.5 hours driving around Northumberland on roads ruined after winter following the sat nav. Mixture of A1 and little roads over the fields once in the general area.
So in the Quarry at Craster...mmm black and winter roads gotta love it.
I'd decided not to update the nav but it was absolutely spot on round Northumberland (the road layout hasn't really changed since the Romans left so being 8 years out of date doesn't affect it at all). So updating so it can be trusted around town centres is back in my mind. Just because it's nice to have the directions between the Speedo and rev counter and not have my phone on a cradle on the dash.
Other than that absolutely uneventful, rode the bumps well, no rattles underneath, stable in the wind, quiet on the cruise other than little bit of wind noise around the front pillar/mirror. It was bought to beat to death but unfortunately I think I quite like the car.
That and the tailgate lip being low at the rear means if you want park like this:
You can then open the boot, sit with a 6 year old with some bags of crisps...and watch the tide come in and destroy your sandcastle.
Character? No.
Fun? No.
Absolutely fit for purpose? I believe it may be.
Also if you aren't going round the doors it uses fuel like a 1.2 supermini. Nearly 47mpg apparently while doing this.
My initial plan for this car was a stop gap while baby was a baby and while my wife was on maternity and it being nice didn't particularly matter it just needed to be reliable and large for a few years anything after that was a bonus. But at this point I'm rooting for it, if we have it 5-8 years we and it shall have many adventures.
Started using this for what it was actually bought for..so first a Visual Aid. This is the boot of the Mazda when I was in the same period with my first born.
Note the sheer level of Tetris required, pram wheels are off, I'm also "cheating" as at this point as we were using the full travel system so it's only the chassis as the seat is in the car.
The C3 the pram and carry cot filled the entire boot to the parcel shelf, to close it you had to take the shelf off the hinges so it would hover on top of the pram.
More recent times...
Even with wheels left on and also the cot that goes on the top half the boot still free (about 260l on volume or a Ford Fiesta boot). The roller blind shelf will close over the top as well or you can leave it open for more space.
I've seen dog guards eBay for 30 quid, this takes the form of a heavy duty vertical roller blind that clips on to pre-fitted anchor points behind the Tonneau and secure to points fitted on the ceiling. You can have both fitted at the same time so if I need more space open one, close the other and stack to the roof as long as it's not heavy stuff. I'm also keeping half an eye out for some roofbars just for the full Swiss army car experience.
Other than being just very useful...it continues to Toyota fairly successfully. It has a lightly squeaky aux belt/pulley at idle, this will be addressed at some point it's been doing it since arrival it's got neither better or worse and can only be heard window down.
Next month it has a Major Service and MOT booked I think I'll get the Nav updated then as well if nothing more pressing comes up. There may be an update then if anything comes up.
Otherwise well only complaint is round the doors and up in the hills she remains a bit thirsty ( as low as 35mpg possible) , cruising economy is nice (genuine 50 mpg possible) but I have a feeling real world measured average is going to struggle to better 40mpg. Which for the 1.8 petrol estate this is the equivalent of is decent enough.
This is a good day..until today it felt like I was going to take it into a main agent and be told despite me having looked it over thoroughly and addressed everything it was actually condemned. Not logical given the known history but in my thoughts none the less given what usually happens when I take the Citroën for an MOT. Sum total of Faults, insecure heat shield which was fixed back on for free otherwise no issues found with belts etc so hopefully that was that.
First advisory free MOT this car has had since 2021..not bad for an old bus.
The eagle eyed amongst you may Notice the MOT is early.
Two reasons, one of which was it was last serviced by Toyota a year ago so keeping the warranty rolling and 2 the Citroën MOT is 29th September. That's usually a bloodbath for my or the warranty companies wallet or both so separating them out is good.
Otherwise somehow the digital key for the nav did not arrive...it's digital I could have bought it and given them it within 30 seconds but apparently that's not how they work. I've paid for that so back another day.
Also I discovered I don't actually like Toyotas...I just like this Toyota. The Yaris courtesy car..well it's interesting given the list price is more than the Auris was 8 years ago to enjoy the sheer amount of cost cutting in it. Materials inside are awful all the panels sound hollow etc. Also was not a fan of driving it, combination of a hybrid system that's always doing something but never quite what you expect and steering that was entirely disconnected just gave it the feel of driving a car in a video game with auto transmission selected.
While this isn't a precision instrument of speed and aerodynamics it just about manages not to be absolutely dull.
Happy with the dad wagon though..so it can go back to its life of this..
  • Like
Reactions: SB1500
So today I got a call from Toyota saying they would not update the Nav despite updates being available and were sending me a refund.
This was not great..but kicked me to actually try to sort it. First up managed to get the security software updated. Once this was done I could now get it to connect to the internet and the E-store. I thought hey great! But no you can't buy maps in the car from the E-store.
I tried many many ways to install it..before finding the right one, probably about 5 hours of trial and error. Takes 40 minutes engine running to update.
Them not doing it has probably saved in the region of 150 quid...and the new housing estate behind mine now appears so seems better.
Hopefully that is now literally everything I was going to do to this done..
  • Like
Reactions: SB1500
It's a ball ache to update... Avensis had the same system. However... with the subscription traffic and fuel prices are surprisingly useful. I'd say get them if you can but last I checked, they only offered 3+ year bundles of those services. Makes putting up with it worthwhile to some extent.
Updated mine last January, but the 2024 pack allegedly didn't change from 2023, so there were some missing housing estates and roads under construction that it constantly tells me not to use. I'd be tempted to update it but then I use Apple CarPlay now.
You could consider going on to AliExpress, giving them the reg / model and letting them advise if there's an add-on box for your system. The same parts local garages are fitting for £700+ will be £100 or so on 4 week shipping from China. That's if the hassle of using the T2&GO system is more than the hassle of pulling apart the dash. Quality of life upgrade?
The new Android based touch screen in later models can update maps via Wi-Fi and the eStore actually has apps! Not that I have it. Although I'm sure you've had a tonne of fun with the 'glass of water' app?! (what were Toyota thinking?!)
Anyway, accurate directions and not sending you down the wrong road, that ought to make you hate the Auris a bit less?
The update process is ok...now I know what to do I could probably have it done in an hour or so including the download & 40 minutes in the car. My main issue was not having a laptop I get the download from and trying all sorts with my phone. Incidentally you can do it with the phone for minor updates but the format comes out all wrong with the big map update. Got the hump and borrowed a laptop for the evening, extracted the files properly. If I'd done that first it would have been easy.
You could just start it and go for a drive which is indeed is what I did while it was updating once you've prepped the memory stick.
But all the smart stuff is dead now, so it has traffic via radio only no fuel prices or live parking, it's just plain no longer supported.
I've been using it without anyway since it arrived so no skin off my nose really, although rendered getting web connection to work pointless.
It's fine for what it gets used for, usually it's a case of driving somewhere on a weekend the Nav itself is competent hopefully better now the maps/speed cameras and limits and pois are updated but all the other bits would realistically have been used if I remembered they were even there.
Mainly it's been updated as quite like to run with the directions muted and the guidance displayed between the Speedo and rev counter on trips I kinda know but might need the odd prompt on then the centre screen is free for radio information and your audio isn't disturbed. Usually it's only unmuted in town centres I don't know.
Don't know whether the glass of water is an initial D reference... although I'm unlikely to be drifting round the Touge any time soon.
At the moment I'm good with it, it's not like I use it for business etc, it's good enough to find a theme park 70 miles away. If I was going from client to client on a tight schedule I'd probably be more bothered.
I should say I don't hate the car at all, as all sorted and fixed up it's a fine thing. Not an interesting thing but sometimes what you need is a good pair of sensible shoes. That and the manual turbo is involved enough to drive I don't fall asleep which is good..
Oh, that's sad to hear. I suspected so as in 2022 I was able to buy one year, then when it expired in 2023 they only offered the 3 years or nothing. Then the system truly is on thin thread of usefulness now. Maybe your capacitive touch screen one is faster / more responsive than the slightly bigger but resistive touch screen version on the Avensis though. If you have 'voice commands' yours is the 'HIGH' (Fujitsu) unit, otherwise it's the 'LOW' (Panasonic?) one.
One of the built in apps on my Avensis was called 'glass of water'. The idea is you turn it on and it 'coaches' you on driving better / smoother. Things like hard braking, hard acceleration and rough cornering made the virtual glass of water 'spill'. You had to try and spill nothing or as little as possible. It's as fun as it sounds.. I think you'll have it on there.
Well true, no better car for the purpose really. Everything else comes with less reliability
It's only a "low" system but my experience of manufacturer voice commands is that you're better off without. To be fair given I stream off my phone it's probably easier to use Google assistant for music related stuff anyway.
The Touchscreen is exactly what I was expecting for an 8 year old satnav it's not great but I don't touch it much on the move so it is what it is.
Glass of water, in the anime "Initial D" the main character "Tak" delivered Tofu in a Toyota Trueno drifting on a Touge road. He had a glass of water in a cup holder, if the water spilled then the Tofu had likely been smashed in the back so he had to drift without spilling the water. I was wondering if someone had a sense of humour at Toyota.
