Oscar the Auris
Toyota Auris Touring Sports 1.2T VVT-iW Business edition TSS
So after 3 years I've finally replaced the Mazda. Leisure lounge regulars will probably be aware of all the malice and aforethought that went into buying a Toyota.
Short version...I've got another baby on the way, the C3 isn't big enough, the wife doesn't want to sell it so I wanted something that did the job I could buy without disappearing down a finance wormhole. I'm aware it will not be to everyone...or perhaps even anyone's taste but this is how it looks day 1 pre-baby damage.
As you can see it's a small Estate...with up to 670l of boot space if you stack to the Roof or 530 under the tonneau.
The interior has aged very well for a car that's nearly 8 and most of the way to 80k.
This picture is mainly because look rear courtesy lights!...the amount of cursing the lack of these causes in the C3.
It has most modcons, so climate control, cruise control, the satnav does allow full post codes (I feared it didn't so isn't as terrible as expected now I've figured it out) and heated seats.
Also 7 airbags and all the modern safety gear...with off buttons as it's pre-2017.
Finally the physically biggest 1.2 I think I've ever seen... compared to the C3 it seems twice the size but in theory they do the same thing and produce about the same power.
Clearly has a water to air intercooler...why it's mounted there god knows. Also yes they don't clean under the bonnet so job for me.
Edit: since posting this done some research it literally has 2 cooling systems (note 2 caps) one is for the engine with a standard pump and the other is for intercooler and the turbo with an electric pump.
Generally presents as a tidy and honest car, one small issue so far..think it needs a TPMS battery. Interestingly it was first registered to Vehicle distribution centre Burnaston, so Toyota owned it for 6 months and then the previous owner to me had it from May 2017, so I'm only the 2nd private owner.
Oh and my son named it immediately.
Future plans are mainly along the lines of beating it to death...although it may be getting 4 new boots to switch to all seasons.
Edited to add on these...
First..I was expecting maybe late 30s early 40s fuel economy. The C3 manages late 40s on a run so this is a surprise.
It's 1400kg so not light at all but it is very slippery in terms of drag apparently and 6th has you just over 2k rpm at 70.
Oh and it's first family duty..to the beach so it's now full of sand, sandwich crumbs and Doritos bits. Nice while it lasted..
How do you make a boring car more boring?
Surely the literal opposite of a Stancenation sticker. Although note the roof rails which are actual blocks of aluminium shaped.
Oh and very exciting update...rubber mats have arrived in an attempt to keep in the interior vaguely presentable.
They are incredibly expensive compared to carpet....but hopefully this car won't have indeterminate brown stains on the carpet and boot floor similar to the C3.
Otherwise car is currently carring quite well, day out today...it did 49mpg with the AC and climate pack on despite me stealth racing things for my own amusement. It's not as fast as the C3 but it's also not slow deceptively quick with the close ratio six speed up to 70. Not like the Mazda where you regularly beat it to death plenty of torque low down
Yesterday I slung a bike in the boot without taking it to bits hence the marks on the boot mat.
I'm very much in the messing with it phase/getting it how I want it... attempting to resist just smashing some premium tyres on it as it's meant to be a cheap run around with space for crap. But tyre noise on the mixture of slightly aged Davantis and Vitto something or others is not great and the brand new Vitto tyres on the front are not quite balanced..I suspect being cheap they aren't particularly round/balanced.
  • Like
Reactions: ben and SB1500
Now let me tell you tale of drama!
Actually no, doubt this car acknowledges the existence of drama in the universe.
So getting it "right" after the previous owner continues and will continue for some time.
The TPS system is literally broken, won't take a reset can't be shut up so until that's sorted constant warning light on the dash. The correct course of action as a Toyota owner is to ignore it but it will be fixed.
First part of ownership was marred somewhat by massive tyre noise especially at higher speeds and a steering wheel about 10-15 degrees off centre.
On the alignment machine she went.
The front wheels were indeed eyeballing eachother significantly.
Thankfully this was Saturday morning before half term since then I've done 700 miles in lots of different situations and in general it's now sorted.
I suppose I'll review it at this point as it's not a car with hidden depths.
Driving:
The 1.2 petrol is generally up to the job, occasionally pulling away on steep hill, and laden you feel like it is regretting it's life choices but generally it is quiet and powerful enough. You have to chase the power band more than in the C3 through the slightly vague six speed box but it's a competent companion.
Further edits from in the future..the gearshift action has significant improved in smoothness after a major service, still slightly vague but no longer occasionally obstructive
Being a 4 cylinder it's sounds awful if revved but you only hear it at high rpm in low gears. I do find it hard to believe that this is the "performance" version of the Auris you can not buy a faster one than this all other versions are slower. The main difference in driving this to the C3 is the weight, both acceleration and braking required big definite pedal movements, you drive the lighter C3 with your tip toes.
Steering it, now the tracking is sorted best described as uneventful. It goes where you point it, due to being an older design (Auris basic design is 12 years old) it's narrow and barely wider than the C3. As a result it feels wieldy and easy to thread on the narrow lanes.
Suspension wise this probably needs a special mention. Despite no mention of any "Advanced comfort" it's absolutely better than the C3, less roll, less pitching, more stability. Also takes speed bumps like a champion. Other thing compared to the C3 is that I'm yet to hit a pot hole that slams the suspension into the bump stops and shudders the structure. Apparently the estate was designed and built in the UK and the suspension is very good at what passes for a country road these days.
Only real negative is tyre noise, it's similar to my old Mazda 3 in that there's a constant white noise on certain surfaces. I plan to sort/improve this by getting rid of the mix of old and crap tyres and replacing with a set of low noise touring tyres in due course but it very much is a feature of the car and there's only so much that will do.
Edit from after I changed the tyres...oh god the tyres were bad. It's not a Bentley with new ones but it's a different car.
Interior:
This depends what you're expecting, I went in expecting some plastic that stops me from seeing bare metal and wires. It nails this brief.
Joking aside if you actually care about things such as soft touch and leather there is soft touch plastic on the dash top, the dash centre appears to be some sort of stitched leather (read vinyl) and the front doors are a mixture of cloth and soft touch plastic. Wheel and gearknob are leather, everything is nicely fitted and accurately moulded in robust materials.
Beyond that it's hard textured plastic or piano black, but it seems to wear very well indeed.
The infotainment stuff is nowhere near as bad as feared it takes a while to boot the Bluetooth from pulling away (a good 45 seconds) and the previous owner clearly didn't touch the nav ever as it's got the factory original maps in it. But the actual nav system seems to work in a leisure capacity. This is the next thing I think I'm going to spend money on...120 quid for the map update to 2024 maps seems like an idea as the basic system is sound.
Centre screen seems a little dim though to be fair I've not looked at brightness it might be set low.
The MFD between the dials is bright and high res and can show many useful things from sat nav directions, stereo information to pretty much anything you can think of.
Everything has an understandable logic to it and things that need a button have a button, although I do miss a volume knob. Even the safety systems are not annoying...despite spending last week on roads strewn with blowing leaves the only time I've seen "Brake!" come up from collision avoidance was in an opposition situation where the car assumed I was about to have a head on with another car rather than slot into a gap on my left.
Living with it:
As you'd expect it's a deeply inoffensive car unless you take offence at things that just are what they set out to be. Boot is big, did a tip run other day didn't fold the seats. Economy for the style of car with a petrol engine pretty damn good. Only 2 tanks so far but average of 42.5 on first tank (with my wife involved) and second tank just me 46.5 that's basically what I expect out of the supermini nevermind 1400kg of estate car with a petrol engine. My only note on that is if you go up into the moors it's not efficient. At a cruise on the motorway or on levelish A and B roads it sits at low RPM in 6th on the Atkinson cycle and will do 50mpg+. On hills it's a heavy car and it reverts to the more powerful Otto cycle so trip to Hamsterly forest returned high 30s low 40s but those are acceptable numbers similar to what the less powerful 1.6 Mazda would have done. Tax is 35 quid a year insurance is probably about as low at it gets for something that isn't a 1.0 67bhp city car. Oh and it has a spare wheel and jack! Even the halogen projector headlamps are decent and the auto high beam works reasonably well.
Finally Photo of it doing what it does...i.e. sitting in the car park of a National Trust place (fountains abbey in case you're wondering).
So sort the nav, new tyres and that's it done and my wife can drive it no bother and doesn't mind driving it, winning.
  • Like
Reactions: SB1500 and Didge3
A good set of Michelin Cross Climates would be my recommendation. Had them on my DS3 and now on my mums Mazda 2. For cars with comfort size tyres there's no real down side tbh. I'm sure with the baby in the car you'd rather float around corners than feel the G's!
I actually ordered an eBay carpet mat job around £10 from eBay, tailored / decent fit, has the little clip in holes for the car... won't be such a shame when they get soiled. Used to do this with the Panda's, a set a year really, probably better than investing in the grossly over priced Toyota mats.
That 'Touch with Go 2' system, I do not miss. Or that 45 second delay for Bluetooth... but you do get used to it. As I think you probably agree, seems promising from the brochure, seems disappointing and lacking on first experience, but then not that bad over time. If you get the 'connected services' (if they are still available, they were in 2022) then it does redeem itself with live traffic en route, suggested faster routes and petrol prices / weather. There's a split screen option on the nav where you can choose weather or fuel prices or something else alongside the maps. Probably was decent for 2015 when that system came out. These systems come in a 'High' and 'Low' configuration. If you have voice control you have the 'High' unit and the better processor, if you don't, you have the 'Low' and slow unit - same as I did. If you get your maps online from eBay like I did, or from a site like satnavishop (looks dodgy, but is legit, used it for my CT updates in January) you'll need to know if you've the Low or High unit. They did 'live services' for one year £25 on their own on the My Toyota site in 2022, when I went to renew in 2023, the only option was maps and live services for a couple of hundred.. emailed Toyota, no real logic in their reply other than to say it only comes bundled now. Used to be £60 for three years of live services only , wish I had've done that at the time. In defence of the 'Touch 2 with Go', the CT has no such live maps / fuel prices which I was genuinely disappointed to lose.
I did a lot of looking into CarPlay upgrades for the system on the Avensis (usually such mods also have Android Auto which I know you'd be interested in over CarPlay). The system is the same on screen blue interface but your Auris I think has a superior / more modern capacitive touch screen and buttons around it, whereas the Avensis had a supermarket self service type resistive touch screen, think it's one inch bigger but I think this difference meant I was only ever to find some one off, hard to find, probably only produced in a small batch Korean mod that could add CP/AA. I think / hope for your style of system, and the Auris being a globally sold car for a long time, that there are decent retrofit mods to add it to your factory screen. Note, these specialist garages fitting them for £700+ are using the same usually Chinese add on head unit boxes like I recently did on my CT. Sure they are fitting it and providing some warranty, but I suspect you're more than capable of doing this yourself in the space of under two hours. The Toyota / Lexus dashes pop off quite easily, usually only a small socket set needed or thin driver to pry off panels. It's not as intimidating as I expected to do on either car. I think if you can find a compatible unit for your car it'll be well worth the £150 ish? If you do and you want any help understanding the Chinglish / cables send me a PM as I had a bit of confusion which they weren't able to understand in the slightest but eventually figured it out.
Sorry for the essays, trying to share what might be seen as useful from my time in the boring Japanese car land... glad I'm not the only FF member in the club now lol
It's going on Goodyear Vector 4 season gen 3s which are already paid for and being fitted Saturday. Had them on the Citroën for years..indeed commuted on them after freezing rain today without incident.
The Michelins are better in snow if we're talking about 2s...but the Goodyears are better at most other things especially wet weather and dry weather and ended up costing about 50 quid a tyre less with various discounts.
To be fair I was planning to pretty much round this thread off Saturday as other than satnav which is not urgent it's up to a standard I'm happy with...however when you list out everything it's needed it's a surprising amount and I can absolutely see why the previous owner cut it loose as at main agent rates it all would have added up quick.
ah brilliant, right time of year for the tyres anyway.
One thing I will say about both Toyota/Lexus nav systems is on long journeys, Dublin to Londonderry, it took me literally as close to a direct 45 degree straight line in the north west direction, not being familiar with the route I followed it in both cars. Took me well off the two decent-road routes and right through the mountains. This was on up to date maps, but the logic of the system I've found isn't the best compared to phones or a TomTom. Though given England has a first-world road / motorway network hopefully that won't be much of an issue to you. Just always take a glance at the route it's sending you down in case it sends you through the wastelands! The CT also had the 2016 year maps on it, Lexus quoted me near £300 for an update, said they're never discounted... no online services for that price on mine... no dice. Think I paid £60.. or £40 for that satnavishop site.
A final thing I've found, used to order my filters / parts (genuine) from ToyotaDirectParts / LexusDirectParts (Fish Bros dealer I think). They did decent bundles on service kits. Much better than my local Toyota dealer. But this year when I was in getting warranty work the workshop parts guy heard and told me he'd basically match their prices pretty closely. I suspect ToyotaDirectParts is applying the maximum dealer discount to keep prices down. Now I can get the parts pretty much same price, no delivery. And I've found they keep in stock every service part / brakes for the cars (which I found DS and Fiat never really did). Toyota also keep their part prices relatively down to earth, usually not much more than all but the cheapest no name parts on AutoDoc - so I've decided just to use them from now on for all they cost. Might be worth checking in with your local dealer and see how reasonable they want to be re discounts as you might be able to get the genuine's for around the same as you'd pay elsewhere. Though again you've probably got quite a lot of better competition choices within driving distance there versus NI.
Plan is to lash at local dealer once a year until the 10 year warranty is up and then probably just use my local independent who looked after the Mazda and have done none warranty bits on C3.
Nav wise I got a quote at 260 to update...which I may do after Christmas depending on some other things. At present I've got a phone cradle for when I go into a city centre or somewhere difficult. But we have the C3 for business things this is more for days out and baby groups etc..so if I'm travelling long distance more likely to be in that (or indeed a hire car). Although I've used the nav and it seemed alright...as long as you don't go to city centre that's been pedestrianised in the last 8 years.
Don't really have time to mess on doing things myself or the tools and this is only going to get worse once a newborn arrives. Hence me getting this in order now as next year..is gonna be busy.
Oh and someone did buy official Toyota mats and they are in lovely condition..but they are hidden under rubber now 🤣
We'll preface this update by posting this..
Same car, older, 20k less miles but not a TSS so 2 insurance groups higher. My car cost over 2.5 grand less than this...and is a full history car and is under Toyota warranty.
And now...let's start with why mine was 2.5k less 🤣.
First the underside I have electronic records of every year the owner paying Toyota to swap winter tyres off and on and they certainly weren't scared of snow. So the underside looked like this.
The rest of the underside including wheel arches is plastic so really just the suspension that got hammered but yeah not good.
Thankfully the supplier agreed to arrange undersealing as part of the deal so now looks like.
Good... unfortunately that wasn't all the weather had knackered. The lacquer on the roof had lifted in a sheet the size of a piece of A4. While it was being undersealed the roof was re-lacquered the rest of the body is largely ok other than the odd scratch or pin dent.
All 4 brakes were done...again these were replaced by supplying garage. As was a lower wishbone on the passenger side (i.e. the side with the edge of the road and potholes) and a CV boot...and 2 TPS sensors.
Unfortunately the garage didn't have any alignment gear and the first time I took it out on the motorway it was clear something was very wrong. Hence the alignment in the last update. This significantly improved the state of affairs but the C3 was still a much better motorway cruiser.
I discovered they'd literally not balanced one front wheel on getting the last remaining broken TPS sensor fixed this did improve things a lot.
However today..the final puzzle piece as it were.
It now cruises beautifully...also more to the point tyre noise has halved as has cabin vibration and you can talk at 70 without raising your voice.
So we are done except perhaps the nav system. None of this was absolutely necessary (other than brakes and suspension for MOT)...but all of it absolutely was for me to actually enjoy the car it was horrible at 70 when it arrived.
How far am I into fixing it up? About 500 quid including the tyres so still 2k ahead of the Carwow one and it now feels good to go for a long time. Of course the supplying garage are about 1500 quid into it as well but I'd bet they paid 6 for it.
I can totally see why the previous owner binned it, it's a case of at Toyota main dealer getting it back into reasonable order would have been 50% of the likely trade in value. Also without this work done...it drove awful but how bad only became clear as you worked through fixing things.
  • Like
Reactions: SB1500
Both my Japanese cars are fairly 'crusty' looking underneath, not as much as your photo, but more than I'd have suspected. I suppose these aren't 'new' cars anymore. But I suspect it will be a long time before yours (or mines) becomes an 'issue' structurally.
Nice to see the new tyres on. Can tell they're all seasons from that tread from a mile away! Just in time for the icy / crappy weather too.
The Avensis had TSS... was quite a few insurance groups lower than the DS with the expensive Xenon lights. Was one of my favourite features of the car when I got it, until I needed the windscreen replaced and it took about three tries to have Autoglass re-calibrate it right. Nightmare / added expense despite lowering my premium each year. Didn't miss it when I moved on to a car without it. It's better (worse?) though than the Merc system, which violently shakes the wheel and slams the brakes on, definitely no good for anyone with a pacemaker. The annoying beep of TSS is far from the worst!
Btw, Toyota dealers sell a set of steel wheels for £260 (set of 4) I was quoted a month ago. Thinking of getting a set next year when I can stomach another few hundred into dedicated winter tyres. Will only do it if they can fit a modern Corolla as if anything happened this car, I'd at least have a usable set of wheels to go on a replacement and not totally waste the money. If it's any use to you going forward, I'm sure they would sell a set for the Auris if not the exact same spec.
Coming from Mazda world, the issue is that unlike the Citroën where the engine/electrics are likely to kill the car long before the floor rots out. This sort of thing is what kills Japanese cars, it'll soldier on for years being no bother then one MOT you'll discover it needs a new subframe followed by sills. Mechanically it'll still be A1 but the underside will have gone. There's very little metal underneath exposed to the elements in this car it looks like an electric car underneath other than that rear beam and exhaust its a large plastic tray from front to back so hopefully it's all good.
I probably could have left it but my plans for this thing are probably in the region of keeping it for 3-5 years or longer if it's still fit for purpose and it certainly wasn't going to get any better. So a bit of TLC to keep it good enough was required.
I've not really argued with the TSS system much, being an early TSS car it's all adjustable all the way up to off. Lane keep assist has a button on the wheel to toggle it on or off. As it is my settings are brake assist on it's least tetchy setting, speed assist beeps off and lane keep assist off, auto lights and mainbeam on, left road sign assist on with no beeps and a 5mph leeway before it goes red. It's said "BRAKE!" twice since I got it both times were in single track opposition situations where I was going to drop into a gap before having a head on with another car. In terms of making insurance group cheaper it is a matter of record that this car is group 12 and without TSS it's group 14. Also when getting quotes it was 250 quid cheaper than a similar Seat Leon with 0 NCB on it. I drive like it's not there mainly...and it lets me which is the level of safety system I like. Anything that yanks the wheel or applies the brakes at random can get in the sea.
I'm not precious about the wheels, they are actually in decent nick because the previous owner had winter wheels, but they aren't fancy and they could be rattle canned if needed being flat silver. I'd imagine the wheels are the Japanese standard 5 x 114.3 although I've not checked, which opens up all sorts of possibilities eg. RX8 wheels but I have no plans to make it more interesting at present.
I don't see the value in 2 sets of wheels for what I do, I don't require the peak performance of a UHP summer tyre, but it's also rarely bad enough to justify a full winter so the all seasons do the job and stay on year round. I could have put a Touring tyre on rather than an all season for slightly better warm weather performance and a bit more direct steering and lower rolling resistance but beyond that it's not a car that needs a high performance tyre. The All season is quieter than most things and also softer riding (it's also softer on the turn in...but if that was a problem I'd not have bought an Auris estate).
Oh and I'll just randomly include this from the other week..
We don't get snow anything like that down this way.
Its very..... black and grey, like someone forgot what colour was when designing this specific car.
Indeed they looked at a Golf and thought "we'll copy that" right down to the blue illumination of the dials and displays rather than the slightly bonkers laser blue down lighters combined with orange/yellow and blue displays of my previous car. Japanese never quite manage the middle ground it's either boring or slightly weird...
However it's unimportant it's probably going to be all sorts of colours by the time I've finished with it.
Everything I've done to it has just been to ensure it's not annoying, is suitable for what I'm going to use it for and ensure it's longevity as much as possible.
We used it Sunday to go to a light trail...due to storm Darragh it was a bit wet occasionally..boots big enough and bumper is low enough I just launched the lad into it so I could take him out of his wet weather gear on the rubber mats under the cover of the roof and tail gate and then store the muddy wellies in a nice wipe clean removable plastic container built into the rear right behind the wheel arch. Pull a handle next to the tailgate it drops a seat and he could climb through without going back outside. Seat goes back up with no effort as the belts are routed to not get caught when you raise and lower them. AC cleared the windows immediately despite a car full of wet people and a boot full of wet gear. When his brother arrives it should be big enough to hold both a pram and shopping at the same time without messing taking wheels off etc.
It's very much a car for life to happen on and around rather than the centre of attention. Pretty much if the story of a road trip involves the car doing something interesting it's failed...as interesting in most contexts would be it's broken or wasn't up to the job. But it will allow the C3s replacement to not be entirely sensible if we want to.. although of course most choices by then will be an electric or hybrid SUV.
Arrr yes.. what goes through my mind when people say a car has “character” usually it either drives badly or has reliability issues.
The more “characterful” the less reliable.
As you say it is a car to do a job and as long as it does its job nothing else matters. The choice of an estate over an SUV while not a popular choice these days, definitely yields a greater and more useful boot
We already have a "character" car...it's more fun than this certainly.
But the time for "character" cars is not cheap to run family transport. It's cost many thousands of mine and the warranty companies money to use a character as an only family car for the last 3 years. It's been fun, it's never stranded us anywhere and there's a lot of memories in it. But generally most of those memories would have happened regardless of the actual vehicle we were using.
Also which cars occupy this space and are characterful? You're talking about a Golf estate...a Seat Leon estate...a Peugeot 308 estate...a Vauxhall Astra estate, Ford Focus estate and a Honda Civic estate. Some of these are more or less reliable than others but none of them are cars of character. That's before we get to by the numbers family SUVs in small medium and large. The small estate car market pretty much exists for fleet buyers private buyers buy SUVs as a result all choices tend to be fleet friendly...i.e. unchallenging.
I did consider the VW group options but at the money I was going to be paying they got expensive once you took in that they'd need a timing belt immediately at the age I was shopping also more expensive insurance due to them hanging the expensive sensors in vulnerable places and having led headlamps at 1500 quid each and more expensive tyres and tax. The PSA VX options no...if it's going to be dull it needs to be reliable nothing worse than a dull and unreliable car it has no upside. The Ford of course would have driven well but isn't a very good estate and didn't fancy an Ecoburst to go with my Purecrap.
Certainly, mine will rot away before the mechanicals give out at this rate. I used to discuss it a lot on here with my earlier cars about a potential undercoating etc, but I've come to realise that in reality, unless I end up really down and out, I'll hopefully never ever actually 'need' to hold on to a car so long that it's hanging together, severely outdated and aged. I know there are some people out there who restore classic cars like old Mini's and 500s, and then others who for some reason, insist on driving horrible boxy Ford's (classics? eh, each to their own)... but I'm not one of them. Outgoing car models are fine to me!
The TSS saved my ass once, big time, I was going around a fairly busy but fast paced roundabout and had someone in hovering around my blind spot, was overly concerned whether they were about to run into me changing lanes as we went around, they thankfully didn't but I only looked forward as the Avensis did the whole 'BRAKE' thing and stopped me speeding into the back of a 44tonne lorry! It paid for itself there..
I noticed in your pictures the alloys are in quite good shape! We have a lot of cobbled streets and granite kerbs here, they can change that rather quickly but I always admire in-tact outer alloys! A lot of people park with tyres at angles where they're squashed against the kerb / digging into it... sends a shiver down my spine to see.
You get more snow than we do so, perhaps I should do the same and not waste the money. It was an experience with the Pilot Sport 3's on the DS which really, really scare me about the PS5s on this car - took it out one January evening in 2021 when it was quite cold / icy here and on the road out of the village anytime I so much as gently applied the brakes, the thing started sliding - no steering or brake control, just turned around and went home. Presumed it was the thin tyres / 'fast' summer design. I'd say that's what made me choose the Primacy's on the Avensis tbh. Not so sure about the CT and the PS5s but thought if I invested in proper 'winters' I'd have about as much hope as possible to get where I need to go.
Re: "Character cars". Very much on the low end, quirky because it has to be like the Panda and others and then there's the high end, super cars or low-volume or odd like the IQ / Cygnet where it's part of the design brief to make it weird or unique! The kind Doug Demuro shows us on YouTube. I don't really think they exist in the middle of the spectrum, every day run of the mill cars like the Focus or Golf. As you rightly say, you considered all of the alternatives - equally as dull, not a shade on the reliability. Think of the Auris as a sacrifice to the car gods in return for trouble free, family days out... and think of something else to sacrifice to the 'family day out' gods in return for as little hassle as possible, though that might be asking too much with multiple kids, if my experience of one six year old in recent years is anything to go by!
I agree the bargains that can be had by buying thimgs that were not so popular are mind bending. And, contrary to the statement by the may thousands who never drove them, the Allegro was not a bad car to drive it was actually decent and reliable. Apart from terminal rot of sills floor fuel tank and axle mounts and suspension that needed constant pumping up it was a decent runabout. Oh and the way it got rid of oil was off the scale. I never did work out where it went to. If they had moved on I wonder where they could ahve got to. But they didn't. Anything a little left field is worth looking at if you are ona budget, as long as you factor in parts price and availability. Ive only had 1 Toyota and it was mechanically indestructible. Toyota service at the time was exemplary too.
One hopes it's slightly better than that allegro sounds 🤣 but yes one of fewer than 800 of this exact car sold...so people were not tripping over themselves to buy one of these, also apparently they sold something like 200 black Auris of all types in 2016 so in terms of sheer numbers it's rare and unusual. Although in terms of looking at it it's naked without a Taxi plate and an Uber sticker.
Wheel and tyre wise it's got unfashionably big tyres on it and small wheels, this means you've got to be pretty committed to actually kerb a wheel.
The C3 with same size wheels and tyres has tyres with basically no writing on them from kerb rubs..but the wheels are largely undamaged.
Next door has a CT in white on black wheels they've nipped the wheels a few times coming in and out the street due to the wheel design and low profile tyre.
I'm yet to find a decent summer tyre that above about 185 section is anything other than an occasional adventure in winter. Below that anything works, but when I got the Swift that was noticeably worse than the Fiats were on 165 and 155 tyres though I managed it. The Mazda on 205/45 R17 was a sledge on a bad day. You'd think you were doing ok, right until someone did something daft and you lost momentum on a hill or you needed to stop at which point physics and the ABS/traction control took over and did nothing useful with so little grip to work with. The C3 has been on the flat stuck outside of my house on Michelin Primacy 3s.
As ever you buy what you need...I don't go winters because we had 2 cars for years, 8 wheels each is a lot of crap to store. Also C3 did 12k a year as only car the likely mileage across those 8 tyres is 3k per set a year...they'd crack up long before wearing out. We get enough bad weather to justify an All-Season but I don't really think beyond that there's much of a use case for a full winter.
I look forward to your updates with this car. When I think back, my mum had various Corsa's and my dad various Astra's and given the memories in those cars, particularly the Corsa's when I started driving one, I have quite fond memories of them. Despite them being nothing special in the world of cars. I reckon any car has the potential to have sentimental value shed on it from everyday life - everyday life that you'd never take your weekend fun car or 'pride and joy' car into, so hopefully that is the case here.
Beyond what has been done in the first few months which basically falls under general tidying and making up for the fact the previous owner did nothing beyond scheduled maintenance. I hope to have very little to update on.
It's due a service in May (technically as it was last serviced by Toyota last may), I'll get it MOT'd then as well just because at present both cars are due a service and MOT in late September and I'd rather they weren't.
Depending on how flush I'm feeling this might be when the satnav gets updated. But hopefully it'll be deeply uninteresting and do nothing much. If anything I'm hoping for that from both cars given i've now got the triggers broom C3 where most consumables and suspension components are less than 3 years old I would enjoy bit of a quieter life automotively for a bit.
To be fair I think you made the right call, i know we talked about other options but the VAG cars can be expensive these Toyotas are under valued and if you only want to throw mud Children and all manner of crap in them, and do that till the thing dies then you want to do that as cheaply and efficiently as possible. It will be interesting to see what replaces the C3
