Background to a poorly twinair
(I've been on here a while, but don't post in the modern panda section often)
The Car: 2013 panda ta - euro 6
Purchased before Covid on 11k miles
Got supplying dealer to investigate a "Misfire" scenario when half-warm
No resolution.. Not shocked..
This is repeatable, and unchanged
If dash display shows 1 bar of temperature on startup,
Car starts perfectly.. But judders for
@ 300 metres, temp climbs to 2 bars.. All good
Done this for another 30k, plugs and Oils have made ZERO difference
BIGGER ISSUE:
At a specific point on a regular run...
It will misfire, lose power and throw an MIL (Dash warning)
Around 1 hour 30 into a trip
IT ONLY does this in warm weather.. All winter is fine
Now the twist...
Did the trip 2 weeks ago,
As anticipated.. 1h30m in it misfires.. Throws an MIL
Lacking in power, etc
BUT.. Whilst still doing 2500 rpm
There Is a chime and the OIL LIGHT is on..!
Appreciating that would "normally" mean that no oil is circulating..
I dip the clutch.. Vehicle is still rolling along at 50mph
Ticks over ok
So.. I turn it off
Wait a few seconds and restart
Oil light now OFF, and misfire less pronounced
Thoughts..?
Low Oil pressure = poor Uniair action
Sounds logical..
But How..??!!
Engine is at 50% of its max revs, oil SHOULD BE CIRCULATING
Maybe the Uniair has a sensor
Been out in the car today @60 miles.. All ok
These were found via MES
(Basic reader found ZERO errors)
Are these manufacturer specific...?
98 denoting OverTemp..??
BIGGER ISSUE:
Now the twist...
Ticks over ok
So.. I turn it off
Thoughts..?
Sounds logical..
But How..??!!
- Model
- TwinAir Euro 6
- Year
- 2013
