Hey where it was previously power loss at the higher RPM's Im now getting Power Loss at Lower RPM's.
So now I have no power no power unless i press the accelerator right in and try and crawl through the revs until the turbo kicks in to give me the power to get anywhere. This doesn't happen when I first drive the car, it starts happening about 2mins into the drive.
I plugged in Diagnostics and after a frustrating half hour have got these from the ECU:
P1555 Accelerator/brake coherency signal low stored.
P0530 - Air Conditioner pressure sensor signal low fatal
P0404 - EGR
Exhaust gas recirculation circuit range/performance
The reason for this fault is that ECU did not receive signal from the sensor. The fault is not detected now, but it is stored
in memory. Clear fault codes, and observe for future appearance of the same fault. Dashboard warning light was not activated
for this fault.
Any help would be appreciated.
P0404 - EGR
for this fault.
