Technical  Newcomer with a problem
gtsrvi
Hi All
let me start by saying hello to all of you Fiat owners out there. I got my Seicento Sporting in April and ran like a dream until recently. About 4 weeks ago it decided that it didn't want to start then it would start OK & run for a while & then not start again. Finally it totally chucked it so I got my local garage to use their fault code reader on it & they said it was the camshaft sensor. I got a new camshaft sensor put on it but it made no difference. The garage then said that it was the crankshaft sensor. when that go put in it started fine but would cut out or idle irregularly & the garage said that either the map or idle sensor was at fault. Now being a bit suspicious I took the car back & got a fault code reader of my own but it finds no faults or pending faults to report. Now I'm not entirely sure what to do. does anyone have any idea what might be wrong & how to put it to rights. Can't really afford to keep shelling out to the garage to replace sensors in the engine.
