<SNIP>
There is no drive to the wheels supplied by electrical power, there is no time the wheels or motion of the car is powered by electrical power. So how is this in any way shape or form a “hybrid”
There IS power supplied to the wheels by the motor, the linitation of (any) mild hybrid is that the motor only adds power to the engine, it does not drive the wheels without the engine running. This is the same as the original Prius (well it would do about 1/2 mile at less than 18MPH). Only plug-in or "self-charging" hybrids will run at speed for usefull distance on battery only.
The fiat system could be considered more advanced than the mark 1 prius as it has a combined Starter/Generator/Motor while the Prius had a seperate Starter/Generator and Motor. This is heavier and the geared drive added more weight than Fiat's belt. The 500 is much smaller than the Prius so a lighter, lower power sytem is appropriate.
What this is is a different take on a starter motor/alternator. It’s all very well fitting a lithium battery, (more marketing nonsense) but people get annoyed at the price of a stop start battery, how much will a replacement battery for one of these cars cost ? A bargain I’m sure and likely only available from fiat.
It's not marketing nonsense, it's using appropriate technology. It is again more advanced than the early Prius.
The Lithium battery state of charge is carefully controlled and should last for years, they are not a service item like a lead acid battery.
Also if you look into it one of Fiat’s selling points is the ability to coast out of gear with the engine off, coasting which is something that no one in the uk is ever taught to so...... that’s a pointless marketing point.
The coasting with engine off (rolling stop start) is totally automatic and transparent to the driver (unless they look at a status display). No training required.
You can argue you don’t like my opinion all you like; makes no odds to me, but can you give any real advantages to this set up, over a conventional car or a Bluemotion type set up? The new 3 cylinder engine is likely to provide an element of improvement in consumption over the old 1.2 or the multiair which had highly questionable fuel consumtion figures. You’ve just spent a lot of money on an actual proper plug in hybrid, this car is in essence claiming to be the same thing.
This set-up is functionally the same as the BlueMotion mild hybrid system and more advanced than the lesser BlueMotion systems like Stop/Start. The BlueMotion name you keep refering too is the real marketing "con" as it covers a wide range of systems and only a tiny percentage of cars ( only > 2019 models) with a BlueMotion badge have a mild hybrid system.
The only thing “Hybrid” about these cars is what the fiat marketing department want you to think.
