No clue about the engine. I've attached some pics. Is there anyway to figure out what it is from these?So have you got a 650 engine or just a 650 head?
Are you running a Dynamo or an alternator? as fuel pumps are different.
Yes the head is a 650 because it has the cross hatched cooling design and also it says 126 on it. I want to understand if it's only the head or the rest of the internals as well, so that I can figure out if I need to get a new 28imb or stick with the 26imbYes the engine is for a 500F or L. How big is the inlet port under that Bakelite spacer. If it is 26mm diameter then you have a 500 head. If it is 30mm then you have a 126 head.
with an alternator you would need a fuel pump with an angled face But you will be ok with a Dynamo.
So do you know what the correct part number for the carb spacer if I want to get a new imb26?So you have a 650 head and spacer by the looks but with a 499 engine it probably does not make to much difference what carb you go for but I suspect you will need a new inlet elbow with a 28IMB carb
Just to throw a complete spanner in the works---yes, it is a 500 crankcase, but has it got enlarged barrels; the 500 crankcase can take up to 652cc barrels. If it has a '650' head, I would be tempted to fit a 126 652cc spacer and, if obtainable, a 28IMB carb---won't do it any harm, and might just helpthe performance a bit.So do you know what the correct part number for the carb spacer if I want to get a new imb26?
Would like to avoid ordering the wrong parts :s
Oh no, don't tell me thatJust to throw a complete spanner in the works---yes, it is a 500 crankcase, but has it got enlarged barrels; the 500 crankcase can take up to 652cc barrels. If it has a '650' head, I would be tempted to fit a 126 652cc spacer and, if obtainable, a 28IMB carb---won't do it any harm, and might just helpthe performance a bit.
Hey, I know I’m torn about the switch. I found someone in the US who is a Weber carb specialist, so I wouldn’t be worried about it being a knockoff.My thoughts re carbs are it does not matter is you have the original 499ccs or a 650ccs upgrade , which I doubt, you can fit whatever carb you like. The original 26IMB carb has its faults including some parts warping or bending but they can be sorted for those that insist on originality. They improved the carb as they went and the 26IMB 10 which was fitted to the 500L being the last and most robust. Having said that you have a 126 head so it seems sensible to capitalise on that and any possible gains by going for a 28IMB carb. So you would need base gasket for spacer, new spacer if you want to replace that chipped one, carb base gasket as the one you have fitted is a 26IMB top inlet gasket if I am not mistaken, top inlet gasket and inlet elbow which should join up to your existing air filter. Some thing like this -
you would need to blank off the fuel return return outlet unless you want to install a return pipe to the tank.
so where would you source your parts from if you can get them?
the internet has been awash with ”new” IMB carbs which fall into two categories. Made under license Weber carbs which have mixed reports and unbranded Chinese fakes that have had bad reports.
So basically the newer production carbs dont have the brass cap on top (the filter is gone correct?). So I can reuse all the same hardware for mounting it as the 26IMB including the throttle arm?The carb You are looking at there will be a Spanish made under licence Weber. The missing brass cap and carb internal filter is a dead give away. Not necessarily a bad carb. I bought a collection of spares from a retiring 500 specialist purely because it included one of those carbs and I wanted to pull it apart to see what all the fuss was about with reports of dodgy carbs. Having restored many of these carbs I am pretty much up on what to look for. I pulled it apart for inspection and found nothing untoward. The carb was sold to a guy in the week before his wedding when he wanted to use the 500 as his wedding car After a sudden carb problem. All went well
I was left thinking that the problem carbs would be the fake unbranded Chinese made ones. I have yet to examine one of those but from the pictures I can see that the castings look poor quality.
thanks. Let me see what I can find.If you have problems I can supply an elbow and gasket set from here in the UK. I also have one last refurbished original Weber 28IMB carb. I have shipped a lot of parts to the US including carbs. We can ship airmail to the US for around £30
The flange on the 28IMB is thicker on one side so you need a slightly longer stud nearest to the rocker cover. They do not have part numbers.thanks. Let me see what I can find.
Can I reuse the stud bolts from the 26imb or do I need new ones?!
Is there a parts number for the bolts?
