- Joined
- May 5, 2006
- Messages
- 894
- Points
- 214
i'm afraid the Klann tool will be very expensive...good luck!
Hi Having just replaced mine on my multiwagon used a very large three legged puller,Originally posted by Dechchair:
"I would guess that the bushes are destroyed when the outer flexi material witholding the fluid type bearing becomes hardened with age but most of all when the bush cente bolt corrodes and seizes to the bush and can no longer rotate within the bush. This will tear the bush apart on suspension rotational movement. Most people have found that the centre bolt is corroded to the bush when they replace them "
I think the bolt doesn't rotate in the bush - the inner tube of the bush is tightened by the bolt when the rear axle is in it's neutral position (carrying the car's weight without extra load) , the rubber and glycol fluid inside the bushes will act as a flexible joint and damper.
That's why the bushes are press-fitted, if they fit too easy the bush would start rotating inside the axle opening...
Please correct me if i'm wrong.....
in that case i assume you pressed the bushes in pushing on the sideplate instead of trough the three openings of the side plate?
I made a simple pressing tool from some metal pieces i had lying around...
Yellowstilo
Can you please state the diameter and length of the three pegs and also what pitch circle diameter the hole centres are on for the pegs and are they drilled 120 Degrees apart.
I fancy making one up ready as my multiwagons done 75 k.
Also thinking of making a jacking tool although we have 50 Tonne press in workshop at work![]()
Anyone got some detailed pictures and accurate dimensions of the old bush outer sleeve with centre removed? internal diameter, overall length, length with top hat etc
Why? Well a bit off the wall, but what about leaving the outer sleeve of the old bush in there, don't even go through the hassle of removing it
http://www.superflex.co.uk/fitting2.php
simply knock out and clean up the soft centre leaving the outer sleeve in place and then top hat type poly bush in either end, tube sleeve down the middle. How quick could that be to replace?
http://www.polybush.co.uk/polybush-grades
It can't go anywhere and couldn't possibly be worse than a fluid bearing with all the fluid gone. Transmitted noise might be worse or it might not be bad at all. You can decide what strength of material is used so you have choice on ride/noise
What is the bush top hat end plate with the three holes in for? Does it line up with anything on the car?
diameter of pegs : 10 mm
length of pegs: 19mm + mounting depth (9-10 mm)
circle diameter: 67 mm
attention: the pegs are mounted slightly asymetrical, fit 1 peg and then use the bush for locating the other two pins.
good luck!
At the worst you might just end up dead..![]()
Dont quite see how???? bushes cant come out once they are fitted can they.
Ok its used by land rovers etc but they are designed to use the application where as the stilo is not?
Your point was that you considered poly bushes wouldn't be substahtial enough but they obviously are if they're holding up Land Rovers, Audis and Porsches. I don't think a multiwagon is heavier than a Land Rover
Do you feel the the geometry of the rear wheels would still be within fiat specs after the modification and how do you feel tyre ware would be affected and tracking issues..?
Of course, geometery wouldn't be affectedand niether would tyre wear Nothing is being movedor realigned
I and no doubt you can remember many an old mini
I can and radius arms and subframes are nothing like a Stilo
At present my rear bushes are fine but I try to think ahead![]()
well klann have still not called me, im gona give it a couple more hours then ring again......
anyways, poly bushes, ive looked pretty hard at the rear assembly now, and i also think that poly bushes will now cause more problems.
the current bushes dont sit in the centre, the bushes are not squarely mounted to the car, so they twist at either end, with poly this would stop the twisting of the axle stopping it moving altogether, or it would shear the bolt altogether. unless there is a flexable alternative with metal insert - or a split design that is has chamfored edges on the inside to allow the twist i dont think it will work.
fiat designed a real micky mouse suspension set up on this car, tbh i think they would have been better just to put a ridgid axle with leaf springs like the doblo. or better yet why not independant....
roy
.fiat designed a real micky mouse suspension set up on this car, tbh i think they would have been better just to put a ridgid axle with leaf springs like the doblo. or better yet why not independant....
Now hang on a sec here; for anyone who's driven a Stilo through some fast bends (and I'm talking driven fast :devilFacts are Roy the stilo suspension set up is a total disaster cheap to install with mega problems when it goes wrong and megabucks to repair...
