Technical Wiring for Rear Light Cluster
SimmoDave
Farnborough (Hants)
Can anyone please let me know the correct colour sequence for the wires into the rear light cluster (right side) for a Stilo 1.4 (2004). I have, from top to bottom (plastic block), Black, Brown, White, White, Grey and Grey (6 wires in total) but not all lights especially the indicator are working as they should? I was going to compare the wiring to the left hand cluster but the wires in the left hand cluster are totally different. Any help would be appreciated.
First thing I would do is check the earths, very common fault, run an extra earth first to make sure.
Then maybe a 12v circuit tester or multimeter if you have one, find what each wire does at a time.
So turn on side light and see which wire is live then turn off side light and turn on indicator and so on brake light reverse light rear fog.
