Had my MOT today, 4th MOT since owning the car and also the first time at this "particular" garage (Guy I know) and my first FAILURE! I think he did it on purpose
My Front Brake Lines are Deteriated NOT split
My Stabalizing Bush is erm... not Stable
My OSF Ball Joint is knackered after I let a cowboy install it.. I knew that would happen
I Asked if it waws worth me replacing the Joints with the Poly Bushes, I was told its not worth it for road use as it is as stiff as a Mofo and the normal rubber ones absorb more pot holyness. He races a 3.0 Alfa he built and said they are only good for the Track.
I asked if I should replace my Brake lines with performance ones and he said "although they make the brakes firmer as they don't expland like the normal Rubber ones when pressure is put on them, when they split, unlike the rubber ones they will just explode and you'll die. Some company had a recall on them.
Apart from that My Brakes are Excellent.. as in they stop the car... but who would know for how long, everything else passed... he didn't even check me window washer, I topped it up especially
If I had bought it to my regular I would have passed.
PS Did you know that for a FREE retest you have to have your car repaired within 24 hours (end of next working day)?
Did you know that because of the Above my car is currently being repaired and I have to pay for it today?
Did you know that I now have to pay £40 for an MOT cause of all the computerisation?
