They are not the same, they are smaller on the Marea. They will go on but they are not the same shape. You will see what i mean if you buy them.
The reason for this is the Marea, Brava will share the same Mirrors but because the Bravo is a 3dr it has larger doors which requires a mirror base to be slightly larger.
However you could swap the mirror casing rather than the mirror base itself. That should do if your replacing a busted one.
i thought he meant just the mirrors. i didnt know the brava and marea used the same bases tho
does that mean the brava and marea have the same front doors?
