Technical  Door switch button fell inside the housing
mkbojan
Hello all, I am new on the forum so pardon me if I wrote in the wrong section, also I know that this is a newbie question but I am not experienced with things like this and also scared to break something.
So a while ago (on a Brava 1.2 16v 80sx) one of the window switches on the drivers door fell inside the housing.
Can I just take off the plastic housing? Are there any hidden screws or is it just held in by plastic clips? What's the safest way to get it off without damaging either it or the door trim?
Unfortunately because of forum limitation I cannot post a photo of it.
Thank you in advance!
Not familiar with Brava itself but on all other Fiats I have had the window switch housing just clips into the door card or arm rest with plastic or metal clips. Should just be a question of gentle levering around the edge with a small screwdriver or preferably a plastic blade until you can see where it is actually fixed, then prize out clips accordingly. The switch itself should also just clip back into place unless something is broken. Hope this helps.
