- Joined
- Sep 14, 2009
- Messages
- 19,899
- Points
- 3,954
Can you not just fit a self illuminated push button switch? The 1.2 with air-con does not use a cabin temperature sensor and with some fettling you can fit a neat switch into that hole.
I've complete set of installation Only without one wiring cable between D008 and D097 but probably need Only 3 wires moreCan you not just fit a self illuminated push button switch? The 1.2 with air-con does not use a cabin temperature sensor and with some fettling you can fit a neat switch into that hole.
Not easilyHm. Before install i check again my body. But AlfaObd cannot program A/C, maybe when i install all hardware option can be done.
Is there any way to activate A/C in Can unit?
It’s a pretty dumb system I don’t see how virginise will help. I assume there will be similar places more local in PolandECU Testing (near Nottingham) can "virginise" Fiat ECUs/BCUs/etc allowing them to be connected into and work with an existing system
Hello, I have already programmed the ecu with a clean memory batch, if necessary, I will also program the BCU, the only problem is that I do not have a virgin *bin batch. could you help me somehow in this matter?Fiat engine ECU, Body computer (BCU) and instruments cluster are electronically locked when first powered on. If you fit a used item from another car it will not work until the chips that control the "linkage" are wiped and reconnected. If you can do the job with your original BCU then happy days. If you need to fit a BCU from an air-con car, it will need to reset to factory (virginised).
Here in the UK, AFAIK the 1.1 Panda 169 never had A/C, even as an option. Having driven one, and remembering how much less driveable it is than the 60HP 1.2, I'd question whether this engine is sufficiently powerful to cope with the extra load.the fact most 1.1 here in the UK at least were the very basic Active model with different wiring and without A/C
I mentioned it, in case the BCU with air-con is different from one without. If they are all the same, then happy days.I have no idea why anybody is talking about a virgin BSI or ECU neither has be changed
It will not add A/C functionality
That’s the problemI mentioned it, in case the BCU with air-con is different from one without. If they are all the same, then happy days.
No a factory reset of the body is a paperweight, It needs keys and VIN programmed in. It’s not like the ECUSo to work, the car would need a BCU and cable connector from a 1.2 with air-con. Splice the new connector into the 1.1 car, set the "new" BCU to factory and finally wire up the new AirCon components.
