So, "hi all"! It was good to meet
panda panda yesterday and I'm looking forward to meeting a few more of you all in the future!
Having being immobile for a while, the 35 miles back to Manchester shook out a few gremlins, but nothing that couldn't be fixed en route and I got back to Manchester in one piece
First thing for today was to make a proper job of the electrics that I'd had to fiddle en route yesterday. Luckily, cleaning earths and re-terminating a couple of crimps fixed nearly all the ailments - such as the NSF sidelight flashing instead of the indicator
I think just reversing lights and the 4x4 lamp need looking at some more, I'll see in the morning. At least having been through a fairly recent MOT, things must have been working and surely can't be too bad... looking OK so far.
The instrument cluster is hanging loose but this made it easier to reattach the speedo cable at least
I'll have to dig through all my old screws and self-tappers to see if I have enough to fix it and the plastics back in place. Not quite yet though as there are a couple more things to check out while it's loose. One thing is that I need to discover where all the heater controls connect as it looks like I've a flap that could do with fixing:
Also took the radio out - old and broken - and made up a quick filler plate out of a bit of plastic to blank off the hole.
We had realised before I set off yesterday that the windscreen washers needed some attention - the rear washer pump was "sealed" in place with insulation tape.
It must have been enough for the MOT but now, a couple of months later, any water that went into the washer bottle poured straight back out
So today I had a think and a rummage in the basement. I found my box of grommets used for electrical backboxes and happily a grommet fit pretty well:
Let's see if that's good enough to last a while! Probably should have tested the pumps, but I'll leave that for a (hopefully pleasant) surprise tomorrow morning...
The washer bottle also needed a lid. Never one to throw something away that "might be useful one day" I tried a number of things for size. The winner? Lucozade bottle cap:
Nice positive fit, very snug, but then comes off nicely with a slight twist
Aside from that - cleaning! I was taught to always clean a car before welding and MOTs... clearly it's not essential
One thing I will say - the trim clips in a Panda are
so much easier to work with than in a Mini. I wouldn't say it's a pleasure but no blood was drawn and no scratched paint (well, no additional scratches at least)!
There'll be loads more cleaning tomorrow - hopefully no more straw to be found - and I'll get it up on ramps but at least all the metalwork I've uncovered so far looks solid enough. Not always pretty but I'm hopeful all the essential welding is done! Again, the MOT reassures me quite a bit! Need to find all the nooks and crannies and look for signs of waxoyl too. I might reverse up the ramps for the first time in my life now I've got the option of drive on the rear wheels... sometimes it's the simple things that I look forward to
My main problem now is that I'm new to Pandas and I need to get used to Panda noises... I'm a little worried about the gearbox and rear axle as they are noisier than I'd expect. I know my Mini noises, so just trying to translate that to Panda. I plan to check oil levels tomorrow, hopefully that's all it needs else I'll try and find where I put my mechanics stethoscope when I last used it several years ago... I've also noticed since getting home there's a quiet background grinding when the clutch pedal is up that disappears when it's down - I'd guess an input shaft bearing. I'll listen for it getting worse but does anyone know if a little noise here might be expected on a Panda?
That's more than enough for now - I'll see what time I get tomorrow but at least I should able to fairly confidently make the short trips I need next week!
