Hey i just orderd some 60mm lowering springs and was wondering if anyone has any pics of wat sort of drop they have , o and would my standard steelies rub lol
Yes probably rub over bumps, a correct tyre and spacer setup will sort this
if its on steelies, then its an s/sx.. then a 60mm drop is a 40mm drop on a sporting, so not *that* low
tyres may rub depending on profiles.
get yourself an anti roll bar.
Pretty much all in the FAQ lovingly assembled by custard.im in the same boat as you mate. i need to find the right tyres. prob end up experimenting for a bit.
do you mean your shocks never acctually compressed the springsi'll tried to lower my car today by 50mm (on sporting shock ), which is not do able at all ... as after the top mount been fitted , there are no compressions on the springs at all .. (if u still put it on, the springs can just out of place ~~)!)
so i recommended getting some uprated shock
o right i know wat you mean , cheersthink he means the standard shocks are too long, i run a 60/40mm drop on my sporting (so thats 80/60 on an s / sx), but have uprated, shortened dampers/shocks to suit.
