Technical Lights on dashboard
julia11
2 days ago while driving home, low tyre pressure flashed up, then abs unavailable, hill stop unavailable, esc unavailable, low pressure unavailable.
When I got home I checked with OBD2 reader it is showing no fault codes.
It shows - abs unavailable, hill stop unavailable, esc unavailable, low tyre pressure unavailable when ever I start the car.
Does anybody have any ideas please?
Model
Tipo 1.6 Diesel
Year
2016
Mileage
48500
Is your OBD engine only..? 🤔 P codes
Likely codes are BODY : B, C and U
Generally those codes could be triggered by one faulty item..
Brake / clutch switches..
Is your tyre monitoring read via ABS /wheel speed? 😉
It was one recommended on here, using the car scanner app, I upgraded to pro
I see you have posted about Dash Cam and other Electrical loads,
Maybe its a CANBUS thing? , depending how you have powered and "Additions" 🤔
I hadn't got round to hard wiring luckily, I just use cigar lighter to power it when I drive
It could be that the battery needs replacing, especially if it's more than 5 years old. The battery on my 2018 Tipo was replaced under warranty at just under 2 years old & has been fine since, but low battery voltage can trigger all sorts of warnings on the dashboard, effectively because the cars computer can't check all the different systems because there's insufficient battery power.
I had the battery replaced a couple of months ago by the AA, but it could have broken
Hmm, it could be a faulty or not powerful enough battery - the diesels take a lot of power to get going. Otherwise I'd be looking at things associated with the battery, like connections, the earth strap (they can come loose or begin to corrode on other Italian cars) & the alternator. It won't be all those warning areas that are faulty at the same time, in case that's stating the obvious. My money's on battery/charging circuit - seems very curious that the car's begun showing errors shortly after a replacement battery.
All was going well, I now have had the tyre pressure unavailable message. I keep reseting it but it is annoying. Tyre pressure is ok, the suggestion so far is new tpms sensor. There seem to be 2 types, 1 in the wheel and one external. When I look using my number plate it shows both variations. Anybody else had this?
Sarah
Do you have a button "iTPMS RESET", located in the left control panel? If yes, you dont have sensors in the wheels. I have never seen a single Tipo with sensors in the wheels. Can you write the win? Or write the error code you found in the service.
Hi, I have used my obd reader and shows no errors. I guess I need the proper diagnostics run on it. I have a button on the right of the steering wheel where I can reset the tyre pressure, is this what you mean?
