Been using Torque Pro to monitor a few parameters recently and noticed my coolant temperature sitting between 73-80 much of the time once the car is warmed up so rechecked today with MES. MES shows pretty much the same.
I let the car warm up whilst monitoring temperature with MES and the thermostat seemed to open at around 80c, let the car sit until the fan came in at about 97c then went for a short drive. Quite quickly, the temp dropped and sat below 80c for the journey.
Can I safely presume that this is opening when it should and staying open (worn out in some way) or, could there be something else at play here?
Ambient temperature and coolant temperature started off at 18C which was approx 4C above actual.
TIA
Ben
TIA
Ben
