dgpphotography
OK, just joined the forum as I have a problem with a 2004 MkII 16v Punto Active Sport. The immobiliser light (car/padlock symbol) is on when you turn the key in the ignition. Cranks as it should but obviously will not fire. New battery recently fitted as the car has stood for 3 months and old one would not hold charge. Both original keys have been tried - no joy. Main earthing point has been cleaned. Before it had this lay-off a new exhaust was fitted (failed MOT) and when being road tested the car cut out but would re-start on the key. When left idling it would also cut out. Blip key activates central locking and the alarm beeps as it always has done.
Any ideas? Can't get it to a garage as no MOT and, obviously, it won't start!
I've looked at other threads and tried the simple things suggested but no joy. Taken the air filter housing off but can't see the small earth lead referenced in one post - different model? Currently has +ve connection on battery with -ve unconnected as I've also seen this as something to try.
Thanks in advance
Thanks in advance
