My 2009 Golf is forwards for changing up. Feels so wrong.
But its a Golf :nerner:
Question for Dualogic drivers -- do you put the car into neutral and pull the handbrake up when you're stopped at a long-ish traffic light? Is there any point in doing this, or does the gearbox handle everything on its own?
I don't use Start/Stop at the moment as I have it turned off, but maybe I should enable it...
Never. Fiddling around with an auto at the lights is like having a dog and barking yourself.
You have an auto so that you don't have to change gears for yourself.* So why would you bother doing so when you stop at traffic lights when there is no need to?
* Actually this is not strictly true in my case - I have an auto because my wife cannot drive a manual.
So is sitting at lights with your foot on the brake in a DL effectively the same as having your foot on the clutch in a manual? Do we know anything about typical clutch life of manual versus DL?
It the same as (or actually is) sitting in gear, with the clutch in an brakes on. Keeping the clutch pedal in can cause the pressure plate springs to loose tension over time. If that happens the clutch won't release fully.
DL clutches should last longer as the computer rev matches, while most manual drivers don't even try. But if both are driven properly there won't be much in it. The clutch should be good for the life or the car either way.
UFI I really doubt the clutch will last 300k miles especially if mainly driven in town!
Rev matching (or double declutching) won't increase the life of the clutch - you're mixing that up with the synchromesh life..
Not at all. The flywheel spins at engine speed, while the clutch plate spins at road speed. If you don't match revs there's slip, and slip is wear. While most wear comes from getting the car moving, anytime the clutch pedal is moving the clutch is wearing unless revs match road speed. Furthermore, matchless agressive driving will kill the throw bearing and while the gearbox is out, most people will also do the clutch.
Sorry, in my experience over 15 years of working on cars and bikes, rev matching (or not) certainly doesn't cause as much clutch wear as you might believe. Think about it - the relative difference in speeds between the flywheel/pressure plate and the clutch isn't that great during gear changes (unless you're comically bad at changing gear, and then CV joints and engine mounts will suffer more!).
However, when stationary and slipping the clutch, the engine will be running at 1200 to 1500 rpm or more (again, I'm referring to comically bad drivers) and the gearbox input speed will be virtually zero.
Might not be so much a problem in your end of the world, but I certainly see a good 50% of drivers riding the clutch to hold a car stationary at traffic lights in London - THAT is what kills a clutch.
Huge issues with my 11reg Punto Evo - had to have new pads & disks at 16,000 miles
Does anyone know what the life of a punto clutch should be ??????
