Technical HGT 1.8 Air Conditioning Hissing (Low side 220psi)
lpwwe06
Hello
I have an issue with my 2001 Punto HGT which is a bid odd.
I have replaced the Expansion Valve because previous owner said it was checked in a garage and they 'faulted' it and I replaced the ca dryer as maintenance procedure.
After that (there was no gas in the car) I charged the system with 550g and a bit of oil to see what goes on. after 40 min vacuum (I wanted to be sure it was as clean as I can get it without taking it apart lol), I started the engine and the compressor engaged with a reading of 250 on the high and the low gauges.
Weird thing is, the Air Conditioning was working well, very cold air and I decided to drive a little like this to see what will happen. After a few days of driving I started feeling AC is going off and I hear a hissing sound from the evaporator.
I want to say that the expansion valve is not the highest quality and has been manufactured in Korea and was pretty cheap.
I am very confused by the situation and wanted to get a few experts minds on it (you guys, everybody around here in workshops don't understand deeper than basic stuff.)
So please, any help would be appreciated.
the picture is when the gas was just charged and the readings are really interesting.
Given the readings you could conclude its likely been over filled.
That sort of pressure on the low side is way way to much and not explained by a poor quality expansion valve.
The recommended charge for your car I believe is 525 - 550, but when adding oil and not knowing what's already in the system I'd tend to go towards the lower end.
The tailing off in the following days is likely because of either an old leak that didn't show up on the vac and hold.
The other possibility is the excess pressure has created a new leak, blown past an old O-ring. I think you may need to look at overhauling all the seals in the system, then recharge at a lower rate.
Hello
Since the high side and low side are too high and apparently they are same pressure there must be a block on the inlet side of the compressor??
Thank you for your reply. Well, that's why I put a little oil with around 540g of refrigerant (maybe 5-7g of oil). I thought about the faulty new expansion valve possibility because that's the only thing that's dropping the pressure from High to Low.
Now I actually am thinking to replace the evaporator, because when I changed the dryer I actually saw it was in a pretty poor condition because I saw the small moisture balls ( I don't know how to call them) that make the dryer to dry, they were all over the place when I flipped the dryer.
It was just like pepper cellar. I think what happened that these particles been pushed and stuck inside the evap. But that still doesn't explain the high-pressure reading on the low side..
Thank you for your reply. I do not know if the compressor is at fault here, I'd like to try a few tests to know that because it is not a cheap part as you know.
If there's a block tho, wouldn't the system not cool at all? and the high side reading is pretty well strangely.
Your readings are saying there is no *difference* in pressure so you might as well have no pressure at all.
The pump appears to be working because you have pressure. But without a pressure difference you can have no flow. On the face of it the inlet to the pump is full of rubbish or something and just needs cleaning.
Thinking this through logically.
The Gas in the system will maybe sit at about 120 - 150 PSI at rest (aircon swiched off) throughout the system as the pressures equalise.
Turn on the compressor and you'd expect to see around 220 PSI like you were seeing. on the high pressure side.
The low pressure side you's see maybe 40 - 50 PSI.
Now you say that you have a new and somewhat questionable expansion valve, and logic dictates that if the expansion valve was stuck wide open then you would get much higher than normal pressures on the low side.
If the dryer was shedding its contents i's expect to see the compressor being damage the expansion valve being blocked and nothing really working rather as the combination of blocked pipes and things would result in an over pressure situation and the compressor clutch would be cut.
But you also report the aircon working well after the regas so that would not suggest a problem with the expansion valve.
My view is that the high reading on the low pressure side is a red herring and something that can happen when regassing the system.
If you disconected the pipes ran the aircon for a while and reconected them I believe you would have seen a more normal reading.
My thought is that a few days later however you did spring a leak.
When you put the gas and oil in, did you add any UV dye?
The only thing you can really do now is look for the leak. what ever the cause you will have to open up the pipe work to fix it, so you might as well check to see if there are any bits of dryer in the pipework, though I suspect not.
I'd probably take the opportunity to replace as many seals in the system as possible as O-rings are cheap and easy to replace. Re gas the system and see what happens from there.
First of all, THANK YOU both for trying to help me out. I appreciate it very much.
I understand what you're saying. Thing is, That's exactly what I think. As the inlet lets say could be filled with the rubbish that the dryer threw.
The pipe from the dryer is routing directly to the expansion valve in my car and plausibility is that the evap could be filled with particles that I can't clean out (the refrigerant passing are way too narrow to clean without special tools of the sort)
I
Thank you. Well, I did measure the pressure when the car is still in the first time I filled the system. It was exactly 150psi on both sides. the minute I turned the compressor on, high is on 240ish and low jumps over the scale.
Though the theory that if the dryer threw it's content into the compressor on my car is very unlikely in my opinion. The dryer connects and flows directly to the expansion valve and into the evaporator.
the AC worked well when I regassed it, now that the evap is hissing it does not cool. but the theory that came up in the comments previous that the overpressure in the low could've blown an o-ring. So maybe I'm missing refrigerant right now I still don't know. Maybe tomorrow I could hook the machine up at work.
I actually did not fill it with UV as when I opened one pipe from the system I saw the inside of the pipe was filled with UV.
I did not understand very good what you meant by saying red herring. As when I replaced the ac parts it took me a while to seal the system (lets say 20 minutes roughly the system was open to atmosphere). Is that worth to try to open the system? how much is a while tho.
THANKS!
