ferrarist75
Have some problems while trying to fit 2.0TS engine from Alfa 156 in MK2 engine bay and need some info.
Is 1.8 HGT front subframe same as other MK2s(1.2)???
I'm using Alfa 156's 1.8 engine block, regrinded to 2.0 size. Same......The subframe's are all the same, I gave up trying to fit the 2.0 in mine (the blocks taller), I just fitted the 2.0 crankshaft & pistons into the 1.8 block.
Dont know if you be able to start 2.0TS engine with HGT ecu.....I'm also planning on doing the same thing. How much is the block height difference? Only problem I'm facing is crankshaft position sensor or the trigger wheel to be exact. I want to use stock ecu because my hgt has traction control etc, it's not really drivable without in winter
No because of the trigger wheel, it's subaru stylish 6 teeth in hgt and alfa has basic 60-2. I have to use hgt crankshaft pulley and weld correct trigger wheel to itDont know if you be able to start 2.0TS engine with HGT ecu.....
I will use all156s electronic...
However from my measurements engine hight, from sump to cam cover seems OK and within range of the bonnet.
