Wire 3. Indicator Wire 1:
My hawk kit came with the the brown wire already spliced into 2, if yours hasn't do this now. (just snip some off the brown wire and splice) Just to be clear the brown hawk wire should now look like the letter 'Y'.
Take one of the brown wires and strip the end. Now remove the cars connector from the fusebox! To do this push down the small tab next to the red securing arm. Whilst pushing this down move the arm to the right.
Now take a flat head screwdriver and push how the grey connector! (thats why i originally called the connector the grey one. Note on the block before you push out the grey part the small numbers on it!
Count along to pin 3
it should be PINK, If it's not you've miss counted haha, small mini note is that on my car there wasn't a wire in number 1 so bare this in mind and count from the holes not the wires.
Using the same method as mentioned before splice one of the brown wires onto this PINK wire.
See the following picture for an example of where i spliced everything:
Wire 3. DONE!
Wire 4. Indicator Wire 2:
The other brown wire needs connecting to wire number 12 in the grey connector block! The wire in the grey connector block should be PINK and WHITE.
