As previously reported, I recently found the exhaust manifold nuts had come loose and the saw that the gaskets were shot, so I took the exhaust to fit new ones off and then found that one of the pipes had come loose (but not detached from the body) Got it welded up but there has been some slight distortion and now the exhaust won't fit back on the studs. I can't measure directly across the mounting points on the engine because of other stuff in the way but using calipers to measure how much out the stud is from the hole, it appears that the correct distance centre to centre should be 31cm. Could some kind person who has an intact exhaust off their car please measure the distance and confirm or correct this distance?
Thanks!
SImon
Thanks!
SImon
