Technical Head gasket blown, balancing options, little money
Thank you all so much again — did the procedure and seems to be going beautifully (no gurgling under the dash when I first hit the gas) and the temp gauge is looking how it should!
I’m going to try to change the oil and filter this weekend, and I’m going to reclean the VVT and see if I still get the p0016
How old is the oil and filter?
Which part of the vvt system are you proposing to clean ?
Unrelated, sorry —
How could I be sure to match the correct axel to my car?
This is a 2011 1.2 peteol,
And someone is selling a rear axel for a 2007 Panda
If you weren't getting P0016 before the head gasket
And the solenoid isn't blocked
It's almost certainly a timing problem
However it's worth doing a phonic relearn as long as you can rev past 4.5K RPM when the engine is warm
I definitely think it’s bc it’s prolly a tooth off, but I know oil needs to be changed and the coolant and oil had mixed with the HG fail
In mean time, I might have come across a brand new oil sump for free, so I might be gearing up to replace that too
I am definitely going to need to prepare to correct the timing
Just so I’m sure, how can I determine exactly how many teeth off it is when I look at it?
Update:
Car making noises that scare me aroun 2500 rpms
Anyone know this sound?
  • IMG_4686.mov
    24.3 MB
I’ve just changed the oil and I’m still getting the P0016 and idling rough, though idk if it would take a little while for the new oil to do its thing
No if the p0016 wasn't there before the head gasket
And the solenoid is clean
No amount of tinkering will correct the situation, and possibly turn a simple fix into a more complex on
It saying there is a mismatch between the camshaft and crankshaft
Pretty much guarantee the belt is off
I’m just planning to take the covers off and redo timing this weekend
We knew it was off half to whole tooth, and with a new belt maybe it stretched ever slightly
Just gotta do the belt again
Weird update – the shop owner who’s going to work with me tomorrow is suggesting a different procedure:
- we leave the belt on
- lock crank Tdc with tool
- loosen the cam pulley while the belt is still on
- with the crank locked in place, put a spanner on the hex part of the cam rod and maneuver it until the cam is TDC with the tool
- then tighten the cam pulley back up
I’m not sure if this will work the way needed or not
Yes
You still need to use the little tool
You can only turn the cam anti clockwise
When The crank is locked all the pistons are half way down so there's no chance of the valves hitting the pistons
Yes
Which little tool? This one?
Also, why can only turn counterclockwise?
