Technical Hand Break
matthewy2
Does anybody know how easy it is to tighten up my hand break on my 1.1 1997 fiatpunto
Thanks in advance
You need to remove the handbrake trim.
Pull the handbrake up 3 clicks, then use a spanner to hold the lock nut and turn the adjustment screw to tension the draw bar. then let off handbrake and check operation.
(obv you need to do this on the flat, chock front wheels etc)
